Tips on cast paint
Old May 12, 2015 | 06:54 PM
derek15003's Avatar
derek15003
Default Tips on cast paint
So my frame was painted using a Sims product bought at a local frame shop, It turned out beautiful, satin period correct, (Pics in profile)
This weekend I am building my blast cabinet, and doing Control arms and knuckles, I bought some eastwood rust encapsulator, and extreme chassis black in satin that I will use on any black parts when they are done.
My question is what is the best paint for that cast look on the knuckles and pivot shaft on control arms. I want something durable and will look good for years. Thanks alot!
Old May 13, 2015 | 02:33 AM
dugsgms74's Avatar
dugsgms74
Not totally sure but I think those were "natural" finish. If so, a nice coat of satin clear works well. Hopefully Alan71 will chime in on this.
Old May 13, 2015 | 03:29 AM
LT1M21Vette's Avatar
LT1M21Vette
Powder coat all the things!
Old May 13, 2015 | 09:18 AM
derek15003's Avatar
derek15003
Well I want trans, rear end, knuckles, shafts to all look the same. so I would prefer paint. To make it easier.
Old May 13, 2015 | 09:23 AM
540 vette's Avatar
540 vette
Eastwood makes a cast paint that looks good.
Old May 13, 2015 | 09:49 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Clear will turn yellow over time. NO paint or finish except natural cast iron will look right. I have used Cast Blast in the past it is as close as you can get with paint, Don't know if they still make it.
Old May 13, 2015 | 09:52 AM
keithinspace's Avatar
keithinspace
Yes, they still make "cast blast". I used it on a few parts. Looks incredible...natural to the quick glance. Durable finish. Like it.
Old May 13, 2015 | 09:56 AM
derek15003's Avatar
derek15003
I have been looking into cast blast. Alot of people have good results. I may end up with that. Thank you ! I love this forum!
Old May 13, 2015 | 10:05 AM
Alan 71's Avatar
Alan 71
Hi d,
I agree that the Cast Blast paint gives a very good look.
It's a bit different than the true appearance of the naked cast iron because it's really TOO nice.
You have to have the parts VERY clean to get good adhesion and you need to be cautious while reassembling to not scuff or scratch the parts with the fasteners.
It touches up well too if needed.
If you want to vary the appearance of the parts a bit you can use Cast Blast, Stainless Steel, and Titanium paints that Eastwood sells.
Regards,
Alan
I first restored my chassis with painted surfaces but have since gone back to unpainted surfaces with some clear paint (applied VERY thinly) or other protectorent on the bare surface.
Old May 15, 2015 | 06:52 PM
69red's Avatar
69red
I have used POR 15 Metal Mask and Eastwoods cast paint with excellent results. The Eastwood paint look more like bare metal.
Old May 16, 2015 | 12:00 AM
derek15003's Avatar
derek15003
Yeah. I ended up purchasing spray gray, rust encapsulator. And chassis black. Should turn out good. We shall see. Powder coating was out. Only due to turn around time and ease of spraying over travel time to the powder coater and back. Plus. Guys in my area charge a mint! Guy wanted 300-400 for a small box of parts, a arms, half shalfs,
No way.
To Tips on cast paint
