74 Starting Problem
Car starts fine 90% of the time, occasionally I will turn the key, no starter. If I open the hood and jump the starter solenoid from the battery connection, car starts fine.
Problem is very intermittant. At that orange override relay on passenger firewall, 'bubba' has attached a black wire (that goes back inot the interior above the steering column) to the Light Green/Black wire, bypassing the orange relay.
The wiring diagram shows the wire on the starter solenoid to be Purple, how does this Light Green/Black wire feed the purple wire on the starter solenoid, as I am guessing it does?
Also, what is the possibility the ignition switch/tumbler is just wearing out after 40 years?
http://www.keystonestatecorvetteclub...tte%201974.pdf
