control valve plate
Old Jun 17, 2015 | 01:01 AM
SwissVette71's Avatar
SwissVette71
Default control valve plate
Can anyone tell me what the plate on the control valve is for and what the purpose is of the raised-90 degree three sided channel on the end by where the hoses connect? The plate seems to add difficulty when trying to attach the hoses. I have looked in several manuals and some of the pictures have the plate and some do not.
Thanks!
Old Jun 17, 2015 | 01:37 AM
toobroketoretire's Avatar
toobroketoretire
Thanks!
What "control" valve are you referring to? Please be more specific.
Old Jun 17, 2015 | 07:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A picture is worth a thousand words. What model year are you working on?
Old Jun 17, 2015 | 08:02 AM
gungatim's Avatar
gungatim
are you talking about the power steering control valve? if so, don't know what plate you are talking about, neither of mine sound like they have any plate like that, and I just did the hoses on the '76...
Old Jun 17, 2015 | 11:34 AM
20mercury's Avatar
20mercury
Default I think.......
Thanks!
I think this is supposed to be a rock guard on the power steering control valve. Wonder if it works?
Old Jun 17, 2015 | 06:12 PM
SwissVette71
Default Power steering control valve plate.
I am referring to the power steering control valve. The plate is attached using the bolts that connect the section that contains the ball stud that attaches to the pitman arm and the hydraulic valve section. I will take a picture and post it soon.
Thanks!
Old Jun 17, 2015 | 07:57 PM
DUB's Avatar
DUB
This plate is basically for protection is what I have figured it out to be...protects the two hoses at the end of the control valve.
The plate should not effect the installation of the hoses if the hoses are attached to the cylinder CORRECTLY first. I can tell you this....that about EVERY hose set I get I have to modify the hoses so they CORRECTLY go into the cylinder correctly...thus routing correctly to the control valve (IMPORTANT!)...and then curved ends of the hoses where they attach to the control valve have to be bent and re-clocked....so they will CORRECTLY go into the control valve without the hoses getting all bunched up because they are being twisted.
DUB
Old Jun 17, 2015 | 11:46 PM
SwissVette71
Default power steering control valve plate.
Here are some pictures, I think. This is the first time that I have attempted pictures. What is the channel piece on the end for?
Old Jun 18, 2015 | 12:41 AM
7T1vette's Avatar
7T1vette
It looks like someone has fabricated a 'protective' shield for the control valve. The channel piece would be there to keep the flat piece from becoming bent. If that is a factory part, it's an ugly one.
Old Jun 19, 2015 | 05:25 PM
SwissVette71
After a bit of staring and thinking I went ahead and hooked things up. I have come to the conclusion that the 90 degree-three sided channel is used to correctly position/“clock” the hoses. Tightening the connection while holding the small-aluminum tubes against the sides of the raised channel results in the hoses being oriented correctly. it does add a little protection as well. And yes, it is an ugly piece.
Thanks!
I rescued this one out of a field and have been slowly bringing her back to life over the last two years. I am hoping to take her for a spin this week!
Old Jun 20, 2015 | 01:29 AM
mds3013's Avatar
mds3013
It is indeed to help orient the hoses in the proper position and it is a stock piece. mike...
Old Jun 20, 2015 | 03:38 AM
7T1vette's Avatar
7T1vette
Looks like a piece that Chrysler could have made....
Old Jun 22, 2015 | 04:51 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
learn something new everyday ! .. on this fourm !
Old Jun 24, 2015 | 10:26 AM
SwissVette71
Thanks Mike!
To control valve plate
