TH400 rubber crossmember mount
Old Jul 2, 2015 | 06:56 PM
teamo's Avatar
teamo
Default TH400 rubber crossmember mount
I removed the rubber crossmember trans mount bracket. It looks like some of the rubber is worn away from the part that touches the crossmember. Should this be replaced or will it make no difference? Also what is with all of the writing and numbers on the mount? It says "pink, orange, black, green" with various part numbers.
Old Jul 2, 2015 | 07:29 PM
DUB's Avatar
DUB
If the mount is still solid and joined together ..I would put it back in and move on. If you are concerned about the light surface rust...then clean it off a little bit and apply some paint and then put it in.
DUB
Old Jul 3, 2015 | 08:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by DUB
...If the mount is still solid and joined together ..I would put it back in and move on...
Old Jul 8, 2015 | 07:33 AM
my 76 ray's Avatar
my 76 ray
Those part numbers are for interchangeable parts. I have no idea about the colors. I agree with the above posters that it looks like it is probably good.
Old Jul 8, 2015 | 08:41 AM
7T1vette's Avatar
7T1vette
Looks like a new mount to me. The lettering is still easy to read, and it's not soaked with oil. It's a good one.
To TH400 rubber crossmember mount
