back up light wiring help 70 C3
Old Jul 12, 2015 | 07:53 PM
jfg15's Avatar
jfg15
Default back up light wiring help 70 C3
Looking for help with back up wiring on a manual 70 vette. Vehicle came with a Nash 5 spd and would like to get the back up lights working. No sign of any wiring under the car. Can someone point me in the right direction. Thanks JFG15
Old Jul 13, 2015 | 07:44 PM
jnb5101's Avatar
jnb5101
Should be a green and pink wire pair for the BU lights.
Old Jul 14, 2015 | 08:33 AM
Alan 71's Avatar
Alan 71
Hi jfg,
On the original 4-speed transmission the back-up light switch was mounted on a small bracket bolted to the transmission case.
A small rod ran from the reverse lever to the switch to turn the lights on and off.
The electrical connection actually ran forward to the firewall, through a grommet in the firewall, and then joined the rear lighting harness running through the interior until it exited through a large grommet in the lower left corner of the rear bulkhead.
I'd think your 5 speed has some provision for a switch…. does it?
Regards,
Alan
Old Jul 22, 2015 | 03:47 AM
jfg15's Avatar
jfg15
Default BU wiring question
Alan - Vehicle does not have any wiring at the firewall grommet> Can you give me clue as to where to look for the wiring under the dash?
Thanks JFG15
Originally Posted by Alan 71
Hi jfg,
Regards,
Alan
Old Jul 22, 2015 | 12:47 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
green and pink wires should tie into the main harness above gas pedal area.
Old Jul 22, 2015 | 06:54 PM
DUB's Avatar
DUB
I have always seen the LIGHT GREEN and PINK wires get routed through a firewall grommet...between the wiper motor and the brake master cylinder/booster area.
The wiring on the factory back up light switch for a four speed is not long enough to make it into the car.
DUB
To back up light wiring help 70 C3
