Clock in 78 Not Working
Old Aug 3, 2015 | 02:20 PM
stoutstuff's Avatar
stoutstuff
Default Clock in 78 Not Working
I'm having work done on my newly acquired 78 SA and I'm told the clock is getting power but not working. Is there someone that can rebuild the clock or do I look for a replacement? Suggestions needed. Thanks!
Old Aug 3, 2015 | 02:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by stoutstuff
...Is there someone that can rebuild the clock...
Yes. http://www.corvetteclocks.com/ You can also Google > Corvette clock repair.
...or do I look for a replacement?...
That is also an option. Most of the aftermarket providers carry clocks.
Old Aug 3, 2015 | 03:02 PM
JimLentz's Avatar
JimLentz
The standard clock draws a bit of current and can drain your battery after a few weeks. If you drive your car often or keep it on a battery tender then this is not an issue. They make reproduction clocks with a quartz movement that use a lot less current.
Old Aug 3, 2015 | 04:08 PM
John 65's Avatar
John 65
If it's the same as my 77 clock, before I replaced it, at the very least I would take it apart and just try cleaning up the 2 contact "points" inside of it with a small folded piece of fine sandpaper or better yet a small file.
Had mine out a few months ago and it came back to life after who knows how many decades. It's been working fine ever since. Good luck.
Old Aug 3, 2015 | 04:16 PM
ddawson's Avatar
ddawson
I used Clock Works. Fast and not expensive http://clockwks.com/
Old Aug 3, 2015 | 04:55 PM
Ryan427's Avatar
Ryan427
I'm waiting to see a thread entitled, "Bought a C3, clock works!" but I don't think it's ever happened.
Old Aug 3, 2015 | 08:45 PM
Sluefoot's Avatar
Sluefoot
Fixed my own....for FREE...by using the steps on the net that have this site in its search words.....combo of using isoprophyl alcohol, can o' compressed air for computers, LIGHT oil (I used container that came wif Wahl hair clippers) & carefully filing the contacts for the mainspring.....did that a few weeks ago and STILL tickin' away!! (Fixed my tach at same time....new circuit board & filter per instructions from Willcox here on this site)
B sure 2 take all the bulbs out of the circuit panel for all instruments & lights & clean the tiny bits o' corrosion at same time!
Old Aug 3, 2015 | 09:53 PM
sullyman56's Avatar
sullyman56
That's funny because it happened. I took the clock out of the gauge package for the 68 convertible, hooked it up to a 12 volt car battery I had sitting around and it started running immediately. It's on the work bench, still running for the last several months. I know this doesn't mean that it will run when I get it back in the car.
Old Aug 3, 2015 | 11:22 PM
stoutstuff's Avatar
stoutstuff
I can see that I'm in good company here! Minor issue with lots of options. Thank for the advice.
Old Aug 4, 2015 | 07:49 AM
AdamMeh's Avatar
AdamMeh
Isn't it sort of a jynx to have a working factory clock in these things?
Old Aug 4, 2015 | 11:15 PM
7T1vette's Avatar
7T1vette
If you are DIY handy, and your clock is a BORG-made unit, buy a quartz conversion kit for your clock. Almost all of the mechanism will be changed out and, when done, the clock will work and WILL ACTUALLY TELL GOOD TIME!!
Old Aug 5, 2015 | 03:19 PM
Ryan427's Avatar
Ryan427
That's a cool bench clock to have
Old Aug 6, 2015 | 12:14 AM
7T1vette's Avatar
7T1vette
Removal and working with the clock may have knocked of the collected carbon/crud on the solenoid contacts (which kept it from working in the car). If you let it sit on the bench untouched, I'd give it several days, at best, before it craps out again.
Exact replacements for the Borg clocks seem to work for about 3-5 years before failure.
Old Aug 6, 2015 | 07:25 AM
LS4 PILOT's Avatar
LS4 PILOT
Me and parents owned dozen of GM cars in the 60's 70's with these crummy cheap electric clocks .....they were problematic when new . They'd run a couple to three years then act strange for the next twenty,
Old Aug 6, 2015 | 09:57 PM
7T1vette's Avatar
7T1vette
All that was needed was a small capacitor across the contact point circuit to prevent point arcing. That would have eliminated most of the clock failures. {Another 10 cents, for capacitor and installation, was too much for GM...}
But, the standard warranty period was 3 years...which most of the clocks would survive. After that (shortly after, in many cases), when it failed, it was the owner's problem. Few of them ever got fixed. Rather, they just got sold with the car.
Old Aug 6, 2015 | 10:39 PM
sullyman56's Avatar
sullyman56
I couldn't tell you if it was working in the car or not since the car was disassembled when I bought it. It's been running on the bench for the last six months. I expect it to quit, but it hasn't yet.
To Clock in 78 Not Working
