RH Lower Dash Differences
Old Aug 18, 2015 | 08:59 PM
Mooser's Avatar
Mooser
Default RH Lower Dash Differences
Does anyone know what the physical difference(s) are between a 70 and a 71-76 right hand lower dash pad?
I believe they interface correctly but I'd like to know what the actual difference is
M
Old Aug 18, 2015 | 11:07 PM
BarryB72's Avatar
BarryB72
Is it 68 no pocket, 69 pocket no crease or stitching around pocket, 70 has a crease no stitching around the pocket and 71- has crease and visible stitching around pocket?
Sorry that's a question trying to answer a question.
Old Aug 19, 2015 | 08:42 AM
Mooser's Avatar
Mooser
68 and 69 are clear (no pocket then no crease) I just couldn't make out what the 70 to 71-76 difference was in the pictures I could find.
Crease with no stitching around the pocket sound good to me
M
Old Aug 19, 2015 | 10:15 AM
DonnieP73's Avatar
DonnieP73
Mooser,
If it will help you to compare, this is the the dash on my 73.
Donnie
Old Aug 19, 2015 | 10:32 AM
Mooser's Avatar
Mooser
Thanks guys
I'm trying to fit my dash back together and the passenger side never fit very well where it meets the shifter console. It's not the original pad (I replaced it after an incident with a screwdriver and the original) with one from a 73 (I think)
I was just checking to see if there was a design change at some point and noticed that they listed the 71 - 77 as the same but a different 70 so as usual I got sidetracked into wondering what that difference was...
Ah well, off I go with the heat gun to see if I can re-shape that tail some
M
Old Aug 19, 2015 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mooser
...68 and 69 are clear (no pocket then no crease)...
A minor point: 68 plain Jane one year only with no map pockets. The most beautiful C3 passenger's side dash pad ever created. ; 69s have map pockets.
Old Aug 19, 2015 | 11:48 AM
Mooser's Avatar
Mooser
But then where would I put my Map?
M
Old Aug 19, 2015 | 12:05 PM
Easy Mike's Avatar
Easy Mike
...But then where would I put my Map?...
We 68 owner's don't need maps.
Old Aug 19, 2015 | 01:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I just posted this to someone else in a different thread.... The lower pads never fit perfect to the console and most of the time the worst pad was the passenger side. You can mess with it some but you'll never get it to fit perfect.
Below is picture of two very original cars that both have original dash pads. The tan one is my own car.. and you can see the right pad is close but it's still not mated up and there really isn't any way to adjust this fit.
Old Aug 19, 2015 | 03:33 PM
Mooser's Avatar
Mooser
Mine is close to the right picture you show and it just bugs me
I've been able to push it into place but there's nothing trying to hold it there of course.
Might be Bubba time
M
Old Aug 19, 2015 | 09:25 PM
0Willcox Corvette
Former Vendor
Heat it.. but you'd have to do it from the inside edge... and then bend the abs sub. It's the only way... and 1/2 the reason my 72 is so close in the pic on the left....
Two ways to do this... one is a heat gun which will probably not work because the sub is pretty thick... but you can try it.
Second way is a bit more tricky but you'd have to be a warrior and not get carried away. Using a soldering iron, you can use it to run a line on the backside and pull the corner inward a bit... You'll also have to hold it until it cools down.... It works but if you go too far and too hard you'll snap it or melt the outer skin.... food for thought though..
third choice involved beer...
Ernie
Old Aug 19, 2015 | 09:47 PM
Mooser's Avatar
Mooser
Thanks Ernie
I was really hoping to use duct-tape somehow but I went at it before supper with a heat gun from the back.
I clamped it to the bench and used a couple of spring clamps to load the corner while I heated it up until it would stay where I guestimated I needed it (about 5/16 over) and then let it cool.
I just test fitted it into place before I came in
Not perfect but I think I can live with that.
Side is close but I don't think I can change anything there, I'll try the cover and see how it looks.
Tomorrow I'll fit the center gauge cluster and see if anything changes but I think it'll be OK
M
Old Aug 20, 2015 | 10:12 AM
0Willcox Corvette
Former Vendor
Nice Job!!! Looks great.
Old Aug 20, 2015 | 12:14 PM
Mooser's Avatar
Mooser
I spoke too soon
And the center gauge bezel pushes it back out, still better than it was but not in alignment anymore
The tail needs to be curved inwards right at the end to follow the bezel and it is right at the thick part so there's no way it wants to bend in the right spot.
The little alignment tab is missing on the center console and it looks like the lower dash is meant to be pushed out by that tab, not pulled it
Back to the duct tape
M
To RH Lower Dash Differences
