Bob's 1969 Resto-Mod Build Thread
Old 06-07-2017, 08:17 AM
  #361
SB64
Support Corvetteforum!
SB64's Avatar
Originally Posted by NAVY08
Sorry, no progress pictures in-between layers of glass - I'm working alone, and no way am I risking getting resign on my iPhone.
Here is how they looked wet - Two layers of Chopped strand mat.
And the final repair - All sanded smoothe...
I was really surprised how clear the repaired sections were.
The back side of the repairs will be ground out, and filled out with VPA. That will all be cleaned up at the end. But the back side didn't look too bad - heres how it looked without sanding after the tape was removed.
Thats all for now.
Looks good, you might want to add another layer to areas that need to be thicker or stronger. Just something to keep in mind.
RVZIO
Old 06-07-2017, 08:52 PM
  #362
NAVY08
NAVY08's Avatar
St. Jude Donor '06-'07
RVZIO
How many layers do you typically use?
Old 06-07-2017, 11:40 PM
  #363
NAVY08
NAVY08's Avatar
In order to ensure the floor pieces are in alignment before I started glassing repairs, I picked up a set of cleco fasteners. I didn't want to final rivet everything in place just yet, and I know several parts are going to go on and off more than a few times when I am doing final assembly.
I just saw the view count at over 35,000. That's pretty humbling. Thanks for watching!
Old 06-08-2017, 06:07 AM
  #364
SB64
SB64's Avatar
I would do one on each side but if you can't do both sides I would do 2 making the second layer just a little wider, not to much. Nice job on not having a straight edge on your matting.
RVZIO
NAVY08 (06-09-2017)
Old 06-09-2017, 12:25 AM
  #365
NAVY08
NAVY08's Avatar
RVZIO
Good. AT least I'm in the ballpark
Old 06-09-2017, 04:33 AM
  #366
SB64
SB64's Avatar
Hey your doing a great job from what I can see. The Clecos pins come in very handy for holding the items to be riveted. In my case some of the holes were to big so I had to use a nut and bolt.
Keep it up!
RVZIO
Old 06-12-2017, 11:15 PM
  #367
NAVY08
NAVY08's Avatar
Keep it up!
RVZIO
I was planning on glassing over and re-drilling the holes that are too big to re-rivet any reason you took this route?
Old 06-13-2017, 12:36 PM
  #368
SB64
SB64's Avatar
Sorry Navy, I meant I had to use a nut & bolt to hold things in place while I did the riveting. The clecos just wouldn't hold in some spots. Everything I did was riveted back to stock.
RVZIO
You get the idea. Actually pretty cool once you get the knack of it and the look.
Old 06-14-2017, 12:16 AM
  #369
NAVY08
NAVY08's Avatar
RVZIO
Got it! Your underbody looks amazing! after working on mine, I can tell how many hours went into getting that look. Did you paint the glass?
Old 06-14-2017, 04:29 PM
  #370
SB64
SB64's Avatar
Got it! Your under body looks amazing! after working on mine, I can tell how many hours went into getting that look. Did you paint the glass?
The under body was cleaned painstakingly with lacquer thinner and PLENTY of paper towels. Not a fun job for sure!
RVZIO
Old 06-15-2017, 11:32 PM
  #371
NAVY08
NAVY08's Avatar
So, lets add fiberglass to the list of things I'm not awesome at. But here is a progress post for one specific repair that was a pretty big step.
Most of the center consul was missing when I got the car around where the shiftier should go.
I started with a cardboard template and then made a fiberboard pattern to use as reinforcement from below to make sure it was in shape before the glass was laid.
I did the repair in two parts (So far, I still need to add some more to a thin spot) The first was the rough flat top part:
Then a rounded edge repair using the aluminum tape as a backing... its not exactly perfect, but should be close enough.
Thats a whole lot of work
Old 06-16-2017, 09:44 AM
  #372
SB64
SB64's Avatar
Default Work
Yes it is a whole lot of work but it is also a whole lot of nice work. There's more to do so do it when you are into it and don't rush. My 2 cents!
RVZIO
NAVY08 (06-19-2017)
Old 06-19-2017, 08:16 PM
  #373
NAVY08
NAVY08's Avatar
The second major repair I did was on the passenger side foot well where it meets the tunnel. I had to guess at the contour where the edge met the tunnel, but I think it turned out pretty well.
The car cover is in the background of the picture above
Old 06-19-2017, 08:24 PM
  #374
NAVY08
NAVY08's Avatar
Repair was done in two parts first the straight part, as far as I cound estimate:
If I had it to do over, I would have done it from the inside, but I made that adjustment for the second half of the repair for the curved portion:
Still working on sanding down the repair and blending it in to the stock glass.
I have a production line set up going where I sand the freshly dried repair, and grind down the next repair section, then tape off, do the repair, and then let set for 24-48 hours, then repeat.
Metalhead140 (06-19-2017)
Old 06-20-2017, 08:17 AM
  #375
SB64
SB64's Avatar
Your getting pretty good at this fiberglass thing. Good way to do the routine of working!
RVZIO
Old 06-20-2017, 09:36 PM
  #376
NAVY08
NAVY08's Avatar
RVZIO
Means a lot coming from you
Old 06-20-2017, 10:00 PM
  #377
chazde3
chazde3's Avatar
Bob, I love checking in and seeing your work progress!
On a side note, what the heck happened to that poor Corvette? It looks like the previous owner's angry ex took a hammer to it.
To Bob's 1969 Resto-Mod Build Thread
Old 06-21-2017, 12:33 AM
  #378
NAVY08
NAVY08's Avatar
On a side note, what the heck happened to that poor Corvette? It looks like the previous owners an angry ex took a hammer to it.
Thanks!
Excellent question. It was ridden hard and put away wet for many years. Definitely got hit in the front and rear passengers side. My best guess is after it was in a wreck someone else picked it up for a track car (It had big 70's style fender flares and green paint with gold flake at one point) And it looks like either a clutch gave out on it, or someone dropped a jack stand while picking the engine out because almost all around the tunnel where it meets the firewall it was broken.
At least two others have started repairs and ran out of either time, money, or patience. Fortunately we have a great community here - I have friends who lend me hand from time to time, and I found a great used parts supplier locally.
Excellent candidate for what I wanted because it was too banged up to ever be put back together "correctly." That and it was really cheap, so I guess you get what you pay for.
Old 06-24-2017, 08:17 PM
  #379
NAVY08
NAVY08's Avatar
Similar repair on the drivers side.
Started with a Cleco clamp to keep it aligned
Then a Aluminum tape backing:
All glassed up!
Still need to finish sanding and grinding - I'm getting a bit behind, but that is ok as I ran out of resign.
Old 06-24-2017, 08:20 PM
  #380
NAVY08
NAVY08's Avatar
Small triangle shaped repair near the wiper motor mounting area.
I forgot to take a before picture, but here it is after the grind:
Glassed up! (I also forgot the masking tape)
And all ground down:
Quick Reply: Bob's 1969 Resto-Mod Build Thread
