Bob's 1969 Resto-Mod Build Thread
Old Sep 24, 2015 | 09:38 PM
  #101
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Originally Posted by Richard454
THANK you-
They are Vansteel.
Cost a little bit more than a composite transverse spring set-up w/ new trailing arms- so if you are having to replace your trailing arms -it's a no brainer. Oh- ask for your 10% Corvette Forum discount.
Nice! I am using C5 Suspension with my build - So I wont be using trailing arms.
If I were doing a stock frame I would definitely use VanSteel - Excellent Quality.
Old Sep 25, 2015 | 02:36 PM
  #102
loup68's Avatar
loup68
Army
Robert, the two small brackets with the captive nuts, bolt between the bottom of the rear frame and help hold the rear fiberglass panel in the license plate area. That heavy plate welded on the passenger side frame, obviously held the bubba battery in the C-2 location.
Hope that this helps you out. Lou.
Old Sep 25, 2015 | 06:03 PM
  #103
NAVY08's Avatar
NAVY08
Lou That does help - Thanks! I will check out the license plate area - see if the other one is still in place.
I figured that plate would have been for a battery. I'm going to have to figure out a battery location myself. I will have to remove the rear compartments to allow my frame to fit.
Old Sep 26, 2015 | 12:08 PM
  #104
loup68's Avatar
loup68
Army
Your right side bumper guard is for a 70-72 Corvette. I am sure that the rear brackets are available if you do not find your other one. Lou.
Old Sep 26, 2015 | 01:09 PM
  #105
Denpo's Avatar
Denpo
Originally Posted by NAVY08
Huh, the front look so much like what was mine initially.
If I was you I'd start seeking for a donor clip from now on. A cheap one would be a big save.
On the bright side, as said Richard, the chassis is in very fair shape.
Keep it up
Old Sep 26, 2015 | 03:37 PM
  #106
vstol's Avatar
vstol
Bob I will be in the garage working on mine on Sunday afternoon if you want to stop by
Old Sep 28, 2015 | 07:11 PM
  #107
NAVY08's Avatar
NAVY08
Lou, Thanks again! I was wondering what the deal was, It didnt look like that piece fell off. I will keep identifying the rest of the chrome and make sure I have a complete 1969 set before I sent them out to be re-chromed.
You seem to know your stuff, thanks for looking out and helping me! I am sure I will have more questions that you will be able to answer.
Keep it up
The Chassis is in great shape - Too bad it wont be getting used on my project I have been looking t clips - used and aftermarket. Where would you look?
Kevin, I can't thank you enough for letting me come to your home and check out your project. Thank you for the advice and your patience in answering all my questions.
Old Sep 28, 2015 | 08:12 PM
  #108
NAVY08's Avatar
NAVY08
Default Post over in Paint/Body
I posted over in Paint/Body to get a second opinion on that front clip of mine. No offense to those who have already given your .02 on it. I just wanted a second set of eyes on it from the paint/body experts before I chop off my front end - Ya know?
Cracked/Fractured Front Clip on a C3 - Can it be saved?
Old Oct 8, 2015 | 01:42 PM
  #109
NAVY08's Avatar
NAVY08
RPM Shipped my Transmission and Differential!
Transmission: Level VII T56 Magnum (TR6060)
Differential: 2010 Camaro 3.70 differential
Expected delivery date: 10/8/2015
Old Oct 9, 2015 | 08:38 AM
  #110
Ranger24's Avatar
Ranger24
Kevin and Robert, I have a nearly brand new copper radiator (BB 454) that I won't be reusing if either of you are interested.
Old Oct 9, 2015 | 02:37 PM
  #111
vstol's Avatar
vstol
Thanks but I have the LS in the car
Kevin
Old Oct 13, 2015 | 07:04 PM
  #112
NAVY08's Avatar
NAVY08
Trans and Differential arrived at SRIII for Mock up... without Bushings
I ordered a set of bushings that will be there tomorrow. So that will get back on track.
Over the weekend, I removed:
The rest of the electrical.
The rest of the interior (Almost)
The pedal boxes
The Bubba patch panels in the foot wells
I was busy and forgot to take as many pictures as I normally like to.
Bubba's patch panel left a fun surprise on the floor
Same on the drivers side
Removed the factors antenna
Anyone have experience removing these? IT looks like its just as easy as drilling out the rivets. Best to come from the top or bottom?
Last pieces of the interior that needed to come out
Antenna out
Progress
Inside of the rear... anyone else notice what I just did?
Insides of the rear tailights
Old Oct 13, 2015 | 07:07 PM
  #113
vstol's Avatar
vstol
Bob I drove over Monday but did not see the car
Old Oct 13, 2015 | 07:57 PM
  #114
NAVY08's Avatar
NAVY08
It's in the trailer. They asked me to take up a little less space.
Old Oct 17, 2015 | 09:07 PM
  #115
NAVY08's Avatar
NAVY08
Default More Media Blasting
Spent an hour on Friday on the blasting cabinet.
I never will cease to be amazed. One of the bumper mounting brackets is pretty bent. Any recommendations for getting it back into shape?
Old Oct 17, 2015 | 09:48 PM
  #116
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Looking good!
Old Oct 17, 2015 | 11:29 PM
  #117
13611's Avatar
13611
Bench vise, channel locks and a BFH.
To Bob's 1969 Resto-Mod Build Thread
Old Oct 18, 2015 | 06:37 AM
  #118
SB64's Avatar
SB64
Default vette
Hey those seat belt brackets look very familiar. To answer your removal question yes just drill them out. Usually from the top where the flat pan head of the rivet is. A small bit in center will do the trick. Putting them back on is a bit of a challenge. Since you are doing a resto mod I guess you could use what ever to put them back on. Going original I had to use the original rivets. A lot of floor board and tunnel repairs. Plenty of laminating and resin in your future. All doable .
Good Luck!
ZIO
Old Oct 18, 2015 | 04:59 PM
  #119
NAVY08's Avatar
NAVY08
Check... Check... Check... Would you use heat too?
Good Luck!
ZIO
Thanks! I think the next session on the Vette will be removing most if not all those brackets that are attached to the fiberglass. Where did you get your replacement brackets? What size bit to drill them out? 1/8th?
Great pictures too by the way
Old Oct 18, 2015 | 05:45 PM
  #120
SB64's Avatar
SB64
The parts came from Zip and Paragon. !/8 bit is fine and a center punch before you drill. Zip has the rivets if you go that route.
