Another head question
Old Aug 28, 2015 | 10:37 AM
nivensid's Avatar
nivensid
Default Another head question
According to one of the leading mail order suppliers, these heads are not compatible with my 78 L48 with stock cam because I don't have the correct cam installed. These heads list for hydraulic cam only, he said I have a flat tappet cam. I responded yes, but it is still a hydraulic cam. This guy is full of crap....correct?
I chose these because they will accept the performer intake and perimeter style bolt valve covers.
Brand:
PROMAXX Performance
Manufacturer's Part Number:
2151
Part Type:
Cylinder Heads
Product Line:
PROMAXX Performance Vortec 185cc Iron Cylinder Heads
Summit Racing Part Number:
PMX-2151
Cylinder Head Style:
Assembled
Cylinder Head Material:
Cast iron
Cylinder Head Finish:
Natural
Combustion Chamber Volume (cc):
64
CNC-Machined Combustion Chamber:
No
Intake Runner Volume (cc):
185cc
Exhaust Runner Volume (cc):
60cc
CNC-Machined Intake Runner:
No
CNC-Machined Exhaust Runner:
No
Intake Port Location:
Standard
Exhaust Port Shape:
Square
Exhaust Port Location:
Standard
Spark Plug Style:
Straight
Intake Valves Included:
Yes
Intake Valve Diameter (in):
2.020 in.
Exhaust Valves Included:
Yes
Exhaust Valve Diameter (in):
1.600 in.
Valve Springs Included:
Yes
Maximum Valve Lift (in):
0.575 in.
Outside Diameter of Outer Spring (in):
1.270 in.
Damper Spring Included:
Yes
Retainers Included:
Yes
Retainer Material:
Steel
Locks Included:
Yes
Lock Style:
Stock
Valve Stem Seals Included:
Yes
Rocker Arm Studs Included:
Yes
Rocker Arm Nut Thread Size:
3/8-24 in.
Rocker Arms Included:
No
Rocker Arm Nuts Included:
No
Guideplates Included:
Yes
Guideplate Pushrod Size:
5/16 in.
Valve Cover Mounting Style:
Center and perimeter bolt
Accessory Bolt Holes Drilled:
Yes
Valve Guides Included:
Yes
Valve Guide Material:
Manganese bronze
Valve Seats Machined:
Yes
Valve Seat Machine Style:
5-angle
Valve Seat Material:
Ductile iron
Steam Holes Drilled:
No
Oiling Style:
Through pushrod
Machined for O-Ring:
No
Heat Crossover:
No
Quantity:
Sold as a pair.
Notes:
For use with hydraulic cam and lifters only.
Old Aug 28, 2015 | 10:43 AM
TimAT's Avatar
TimAT
Unless you've changed the cam, you have a hydraulic flat tappet cam.
Old Aug 28, 2015 | 10:46 AM
nivensid's Avatar
nivensid
yes, stock cam so these heads will be compatible?
Old Aug 28, 2015 | 11:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The specs list a 1.270 spring for .570 lift....so yes, these heads will work for flat tappet.
Jebby
Old Aug 28, 2015 | 11:20 AM
nivensid's Avatar
nivensid
Jebby
Thanks Jebby
Old Nov 11, 2023 | 09:51 PM
Opium Motors's Avatar
Opium Motors
Default Wolf in Sheep’s Coating
Something to consider
I built a small journal 1967 327
Steel Crank only needed polishing, tough old cranks.
Rods, I used Eagle I Beam
Pistons. Forged 30 over Kieth Black 10.5:1
Cam, better than stock but not too loopy.
On top I use factory yet ported, double Hump heads and factory Aluminum Intake and valve covers.
I done several build such as this to Chevy and Fords of the 60’s
so that the outside looks totally stock while the inside is anything but.
Last edited by Opium Motors; Nov 11, 2023 at 09:56 PM. Reason: This was for the 327/300 build, somehow found its way here, please move
Old Nov 12, 2023 | 08:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
in the summit description is plainly states hydraulic flat tappet, so I dont know what the tech guy was thinking. THe other 2151 head is a 2151HR which is probably for hydraulic roller lifters but they dont provide a description for it
Old Nov 12, 2023 | 08:29 AM
Rescue Rogers
the applications page lists it ...must be some gen z kid
https://www.summitracing.com/parts/P...ions/year/1978
Old Nov 12, 2023 | 08:42 AM
Rescue Rogers
it lists those as unavailable but heres some aluminum heads that are similar
https://www.summitracing.com/parts/e...make/chevrolet
https://www.summitracing.com/parts/b...make/chevrolet
To Another head question
