firewall replacement.
Old Sep 3, 2015 | 08:52 AM
derekderek's Avatar
derekderek
Default firewall replacement.
looking at a project. light engine fire. left fender a little cooked on top near firewall. master cyl is roasted pretty good. there is 1 pic of wires by fusebox with melt damage around wire harness, but fusebox looks ok. there are no interior pics, but windshield is intact and shows no soot on it. wiper door is still the color of the car, not cooked. can firewall be replaced without lifting body off chassis? if not, can body be lifted with standard engine cherry picker? what does the body, without nose weigh? coupe. and roughly what percentage of market value would a hulk like this be worth? rear clip, doors, wheels make it LOOK like it was a nice car before fire. it is a car that can't be viewed till after sale, unfortunately. I have been a backyard a$$hole mech for over 40 years and do copiers for a living so i know electrical issues better than most.
Old Sep 3, 2015 | 10:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...can firewall be replaced without lifting body off chassis?...
Not easily. Have you considered salvage yard pieces for the damaged area might be more practical than replacing the entire firewall?
Why can the car not be viewed until after the sale?
Old Sep 3, 2015 | 10:16 AM
derekderek's Avatar
derekderek
so you can cut the top section and replace reasonably? i have seen a couple of sections on ebay decent money. how late a firewall will work in this car? just found this car this morning and i figured here is best place to get opinions on it's doability. and i assume any firewall work will be mucho easier with no engine-trans in the way?
Old Sep 3, 2015 | 10:26 AM
Alan 71's Avatar
Alan 71
Hi dd,
If you get a look at the AIM for the year car you're considering you'll see that the firewall is made up of several pieces that are bonded together.
Depending on just where the damage is you may be able to just replace those damaged areas if they are somewhat confined.
I'd certainly take a look at that possibility before considering a complete fiberglass cowl replacement.
In my 71 AIM the info is shown in UPC1, sheets A13 through about A17.
Good Luck!
Regards,
Alan
Sheet A13 shows the 'top' piece which might be just what you need.
Old Sep 3, 2015 | 10:40 AM
derekderek's Avatar
derekderek
ok, where do i get an AIM? and are they diff for each year? or is most info good across several years? i also have a 75 i lucked into that is all around pretty nice. also if dash has to come out anyway and redo wiring harness, i am considering installing fact air into it. i know, vintage is easier and cheaper in the long run...
Old Sep 3, 2015 | 11:32 AM
Alan 71's Avatar
Alan 71
Hi dd,
The cowl area fiberglass is similar for many years but there were some subtle changes.
It will take an experienced fiberglass person (Dub?) to know what will fit and what won't, or some detective work on your part.
The AIM is specific for each year, but there is certainly 'carry-over' from year to year.
The AIM is available from many of the larger venders… usually about $20 +-.
Regards,
Alan
Old Sep 4, 2015 | 07:09 PM
DUB's Avatar
DUB
The 'firewall' is installed BEFORE the front clip is attached and bonded.
It depends if the firewall can be sectioned in .....while the body is on the frame.
I know some people have used it...I know I would not. I use a chain joist (1/2 ton)...or my lift.
IF you are referring to the 'nose'...as being the FRONT CLIP. About 600 pounds as an estimate. I have never needed any reason to weight the cab section (stripped out). And I can tell you...that if you use the straps and lift the 'body' WITHOUT the front clip attached...it will be really rear end heavy and tilt like crazy. The front clip keeps it level.
No comment on what it is worth. Personally/professionally 'speaking'...IF I can not look at it...I would not pay much for it at all.
Depends on how much of the firewall you plan on repairing or replacing. AND until the total extent of the burn damage has been checked out...it is hard to say.
YES...having the engine and transmission out is helpful.
DUB
Old Sep 4, 2015 | 09:21 PM
derekderek's Avatar
derekderek
DUB i really appreciate your time and expertise. now gotta wait till monday see if i get a counter-offer...
To firewall replacement.
