Fusible link question
Old Sep 28, 2015 | 05:06 PM
E.Murray's Avatar
E.Murray
Default Fusible link question
On my '68, I think the picture below is the fusible link. The two wires coming out the bottom of the rubber thing go from the starter over to voltage regulator (I think... memory is fuzzy). I think the wire coming out the top is probably for the ammeter (thanks DUB!). So, my question is, how do I repair this? Is the solid rubber cylinder part of the fusible link or is it just a really odd way to splice the ammeter wire into the 12V? I assumed the first part of the ammeter wire was the fusible link?
Old Sep 28, 2015 | 05:15 PM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Not seeing the picture....
Old Sep 28, 2015 | 05:23 PM
E.Murray's Avatar
E.Murray
Picky picky... Sorry about that. I fixed it.
Old Sep 28, 2015 | 05:52 PM
zuendler's Avatar
zuendler
Funny, this week the insulation of my fusible link at same location broke and caused a short to the brake line near by. A lot of smoke came out of the hood.
And the other link did not look much better either. The insulation of this wires gets old and breaks.
Ok, now im talking about the ´69 wiring:
At the horn relais come together:
- thick wire from the alternator
- thick wire to the starter and from there to battery
- thin wire (black-white) with fusible link to the ammeter and from there to the starter
- medium thick wire with fusible link to the cockpit and all controls, light etc.
Fusible links are nothing other than thinner wire than the wire that is to protect. But they have a special insulation, I guess it can survive higher temperatures for the case the wire melts down.
Cut the rubber part away, there a normal crimp connection under it. Replace the fusible link with a wire of the same gage, but try to get it with silicone insulation. Or replace it with a fuse holder and fuse. The ammeter should not get more then 3 amps.
Old Sep 28, 2015 | 09:11 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
These might help
There is special fusible link wiring needed, thanks to members who originally posted these pics.
Old Sep 29, 2015 | 04:04 AM
zuendler's Avatar
zuendler
The "special" wire of the fusible link is just tinned copper, as jused in many other standard wires too. But the heat resistant insulation is what matters.
Old Sep 29, 2015 | 07:34 AM
Calo69's Avatar
Calo69
That's what makes it special.
Old Sep 29, 2015 | 09:17 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Fusible links
You can get fusible links at any NAPA store. I would solder them in with shrink tubing. I believe the rule is to go down four sizes for protection. A 12 gauge wire would require a 16 gauge fusible link. I think DUB recently had a great post on this very topic last week. Jerry
Old Sep 29, 2015 | 07:25 PM
DUB's Avatar
DUB
It is always best ...if replacing a burnt fusible link...is to re-crimp in a the SAME GAUGE fusible link along with its LENGTH!
If you are concerned about color of the fusible link being correct...do a google search.
YES...the thick rubber insulator 'block' is just that. it is protecting/insulating the butt connector....AND...providing some support to this fusible link where it comes out past the ends of the butt connector where it has been crimped.
SO...if my customer is not worried about it being 'perfect factory'. What I do is slide on heat shrink tubing and start building it up by adding multiple layers of heat shrink tubing and or carefully wrapping the area with electrical tape so the heat shrink tubing ends up looking like the rubber block.. This obviously gives the fusible link wire that is coming out some support...depending on how far out I bring the heat shrink tubing.
DUB
Old Sep 29, 2015 | 08:33 PM
7T1vette's Avatar
7T1vette
The fusible-link is the wire BETWEEN the two rubber (probably phenolic) black lugs on the wire. Those lugs...and the insulation around the fusible-link wire...are non-flammable, so that, when the fusible-link melts, nothing catchs fire. The fusible-link wire is merely wire that is one or two AWG sizes smaller than the power feed wiring to which it is attached (if 12 awg wire feeds a component, the fusible-link wire will be 14 or 16 awg).
These links are in locations where a short should not occur, normally...unless there is a critical component failure which COULD cause a dead-short. In that case, the hardware needs to be protected, so a fusible-link (rather than a fuse, which could fail from age on its own) was the preferred method by GM. Dead-short: fusible-link wire melts FIRST--but does not cause any flames to be produced.
So, replacing a fusible-link should be done properly...with another fusible-link. Not only should it be smaller wire, but it should have non-flammable insulation and non-flammable terminators (lugs) separating it from the regular wiring.
To Fusible link question
