Engine codes
Old Oct 4, 2015 | 06:09 PM
73BBVette's Avatar
73BBVette
Default Engine codes
Just lifted the body off on my '73. While doing a little wire brushing along the frame and engine.......I find these engine markings. I assume the "HIO 72" I found on the back of engine block and rear of the intake means High Output and the year the engine was assembled. Not sure what the Conv1 is suppose to indicate. Any ideas?
I find it funny that by 1972/73.....275 HP was considered high Output. Anyhow.....I feel inspired to bring this engine up to it's potential in the rebuild.
Old Oct 4, 2015 | 06:16 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
It's the casting date for your block.
H 10 72.... August 10, 1972.
Regards,
Stan Falenski
Old Oct 4, 2015 | 06:18 PM
ed427vette's Avatar
ed427vette
The H stands for August, the number 10 after it is the day and 72 is the year.
Old Oct 4, 2015 | 07:00 PM
73BBVette's Avatar
73BBVette
OK....I'll buy that. So there's an 8 day difference between casting date and assembly date?
Old Oct 5, 2015 | 12:20 AM
ed427vette's Avatar
ed427vette
It can be. My 69 has a 12 day spread.
Old Oct 5, 2015 | 07:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. Block casting dates and engine assembly dates almost always vary with the block casting date being the earliest. You'll find the same time lag with head and manifold casting dates.
To Engine codes
