Starter Question
Old Oct 19, 2015 | 12:29 PM
derekderek's Avatar
derekderek
the different starter bolt pattern is to change the offset for the different diameter starter wheel. when upgrading trans, you have to know what starter wheel you are getting and then know whether or not it'll bolt to your crankshaft...anything after 85 uses a smaller bolt circle on the crank flange and won't fit an older engine.
Old Oct 19, 2015 | 12:36 PM
bj1k's Avatar
bj1k
Originally Posted by loup68
BJ1K, I beg to differ, and agree with derekderek. My 68 had a 327 and 153 tooth flywheel. The starter bolts are straight across. The 350 has the staggered bolt pattern starter, for the larger 168 tooth flywheel and also has a larger bell housing. Lou.
Differ from what ? The 327 has the same diameter ( small ) flywheel as the GM 6 cylinders which takes the starter with the bolts straight across. The 350 takes the larger flywheel with the staggered bolt starter . Where do we differ ?
Old Oct 19, 2015 | 06:43 PM
loup68's Avatar
loup68
Army
I am sorry, but you confused me with the "but the starters will fit standard or automatic but it is determined by 6 or 8 cylinders". Lou.
Old Oct 19, 2015 | 09:21 PM
bj1k's Avatar
bj1k
OK , 8 cylinder with large flywheel for standard or large flex plate for automatic would take the starter with the angle bolts. (Same starter). 6 cylinder GM or 327 with small flywheel or small flex plate would take the starter with the bolts straight across . (Same starter) for standard or automatic.
Old Oct 20, 2015 | 09:07 AM
Kid Vette's Avatar
Kid Vette
There are 2 different Chevy starters for 2 different diameter flywheels/flexplates. Straight bolt pattern on the left is for 153 tooth; offset pattern on right is for 168 tooth. Nothing more to it than that.
Old Oct 20, 2015 | 10:33 AM
derekderek's Avatar
derekderek
Precisely. And you need to get a starter wheel that works with the late model trans you are retrofitting and the 2-piece seal orig engine you are hooking it to.
Old Oct 20, 2015 | 11:47 AM
bj1k's Avatar
bj1k
Exactly what I have been saying.
