Starter Question
Old Oct 13, 2015 | 01:28 PM
The Punisher's Avatar
The Punisher
Default Starter Question
I have a '75 that I am converting from auto to manual. Is the starter the same or is there one designed for manual transmission ? Thanks
Old Oct 13, 2015 | 04:01 PM
bj1k's Avatar
bj1k
Corvette starters will work with manual or automatic .
Old Oct 13, 2015 | 05:20 PM
The Punisher
Both autozone and Napa have starters listed for auto and manual trans. And the price for the manual starter is more.
Old Oct 13, 2015 | 05:30 PM
The Phantom's Avatar
The Phantom
Check the Rock Auto site, it will show you all the options.
Dave
Old Oct 13, 2015 | 05:54 PM
The Punisher
Dave
Rock auto is showing 2 different starters too. I'm confused
Old Oct 13, 2015 | 06:27 PM
The Phantom
So put in a mini starter and call it a day! LOL
Dave
Old Oct 13, 2015 | 07:03 PM
loup68's Avatar
loup68
Army
There are two different sized flywheels. 327's and automatics have 153 tooth flywheel/flex plates. Manual 350 flywheels are 168 tooth, except for L-88's. But I am not an expert on this. There are two different starter mounting bolt locations between the two sizes. Lou.
Old Oct 13, 2015 | 07:56 PM
The Punisher
Originally Posted by loup68
There are two different sized flywheels. 327's and automatics have 153 tooth flywheel/flex plates. Manual 350 flywheels are 164 tooth, except for L-88's. But I am not an expert on this. There are two different starter mounting bolt locations between the two sizes. Lou.
I read that the manual 350 is 168 tooth.
Old Oct 13, 2015 | 08:04 PM
Sunstroked's Avatar
Sunstroked
Many gen 1 small blocks are drilled for both a straight starter mount or an offset starter mount. My 72 block is original, it had an offset starter originally. I'm using a mini starter with a straight mount. It cranks my 10:1 compression engine very fast, and without any hot engine drama the big bulky original style starters are known for. Verify that whatever starter u buy will fit your flywheel. Most mini's will fit either the 153 or 168 tooth flywheels.
Old Oct 13, 2015 | 09:09 PM
The Punisher
My goal was to use my starter that I already have. So with that said only bj1k has said that it will work.
Old Oct 14, 2015 | 08:32 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
There are 2 different P/N's for the starter motor in 1981...one for manual, a different one for auto...( don't know about the 75's )...Good Luck!
Old Oct 14, 2015 | 10:51 AM
loup68's Avatar
loup68
Army
I corrected my post, Punisher. Thank you for correcting me. The main thing is that there are two different applications between manual and automatic. Lou.
Old Oct 14, 2015 | 11:09 AM
The Punisher
No problem, I ordered a starter for manual trans. If I don't need I will return it.
Old Oct 18, 2015 | 01:26 AM
The Punisher
Just a follow up. I had to use the starter for a manual transmission. The one I had for an automatic would not fit into the bell housing
Old Oct 18, 2015 | 04:58 AM
hunt4cleanair's Avatar
hunt4cleanair
The nose gear in the starter is different to accommodate the different flywheel, manual vs auto and therefore the different part numbers.
I took a 78 starter with an auto part number and had it converted to manual while maintaining the date code and the nose had to be replaced for the manual. Kept the auto nose.
Old Oct 18, 2015 | 05:54 AM
derekderek's Avatar
derekderek
it isn't the trans, it is the flywheel diameter. there are both auto and man trans flex plates and flywheels out there in both 153 and 168 tooth. the trans you got came with the smaller diameter starter wheel and needed the different starter nose. i think in most cases one could get a 168 tooth starter wheel that would fit their converter and crank flange. i just realized...C3 is all 2 piece seal engines at least as built. and these newer transmissions come with flexplates that are all designed for 1-piece seal cranks.
Old Oct 18, 2015 | 06:26 PM
Ironcross's Avatar
Ironcross
this is true, but not necessary .....with dummies behind the counter it would be necessary for individual listings or they would never sell a starter.....
by the way they are the same for some applications.......auto or stick........take your old one with you as the fit is the same
want to have fun? ........ask for a heavy duty....
1975, 350 and 454 starters are the same look and fit except the HD units are only OE on 454`s but fit the SB`s
To Starter Question
Old Oct 19, 2015 | 08:55 AM
bj1k's Avatar
bj1k
GM Six cylinder and eight cylinder also use different size flywheels so there are two starter bolt patterns . One bolt pattern is straight across and the other one for eight cylinder is at an angle . But the starters will fit standard or automatic but it is determined by 6 or 8 cylinder.
Old Oct 19, 2015 | 09:12 AM
derekderek's Avatar
derekderek
It is determined by the flywheel diameter. These trannys are from later model cars and you need to obtain a 2-piece seal flex plate that will,fit the new transmission's torque converter.
Old Oct 19, 2015 | 11:58 AM
loup68's Avatar
loup68
Army
BJ1K, I beg to differ, and agree with derekderek. My 68 had a 327 and 153 tooth flywheel. The starter bolts are straight across. The 350 has the staggered bolt pattern starter, for the larger 168 tooth flywheel and also has a larger bell housing. Lou.
