Where does this wire go?
Old Oct 16, 2015 | 04:22 PM
cmhidinger's Avatar
cmhidinger
Default Where does this wire go? 1970 BB...
1970 BB, brand new engine wire harness. It's to the right of the wiper motor as you look at it from the front. Any ideas?
Old Oct 16, 2015 | 05:54 PM
loup68's Avatar
loup68
Army
Chad, please state the year of your Corvette in any post needing information! You have a 1970 and every year has different wiring everywhere. I have a 68 so I am sorry that I can not help you on that, as GM wired my one year only wiper motor by cutting the ground and leaving the wiper motor hot all of the time, even with the key off and out of the car...genius engineering at it's finest! Lou.
Old Oct 16, 2015 | 07:28 PM
Mooser's Avatar
Mooser
Not sure about the black stripe but I believe that wire should be the one that goes over to the wiper-door switch and allows power to the wiper motor once the door is open
M
Connects to this guy on the 72's anyway
M
Old Oct 21, 2015 | 09:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
wrong guess..
Old Oct 22, 2015 | 07:33 AM
Alan 71's Avatar
Alan 71
Hi W,
I'm thinking the same as M!
Regards,
Alan
(I believe the back-up lamp is a 2 wire (green/pink) connector) that comes through the firewall out of the dash harness, it's not part of the engine harness).
Old Oct 22, 2015 | 07:40 AM
jnb5101's Avatar
jnb5101
That tape is not GM. It looks like a splice, possibly for a 12v source for some after-market accessory.
Old Oct 22, 2015 | 09:50 AM
0Willcox Corvette
Former Vendor
I think it may be the jumper connector for TI ignition cars...
My 70 had TI ignition and I removed it in the 80's. (I still have everything). But I also replaced the harness in the late 80's... I have the same connector and it is taped like yours right at the clip on the firewall. The wire color is actually black with a pink stripe.
When you trace the wire back it goes to the ignition switch.
Willcox
Old Sep 3, 2025 | 08:00 PM
Hrider60's Avatar
Hrider60
Navigator
I have the same wires n my 68 with a double connector and everything works. No backup lights. Stand corrected. The lightghts would be under the rear bumper.
Old Sep 3, 2025 | 08:36 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Old Thread, but I have the same connector on my '68 that I sealed with harness tape.
Use a multimeter to check for voltage with KEY OFF KEY ACC KEY ON KEY IN CRANK POSITION
To Where does this wire go?
