Complete guide to body removal?
Using the dolly I designed supports the body at the original body mount points.
I ran a lag screw in through one of the #1 mount locations and one on the opposite side in the #3 mount location.
I drilled a hole in the upright first since I was screwing into the end-grain of the uprights.
Regards,
Alan
I had wicked bad luck with my tech who did mine, I guess he meant well but just dropped the ball over and over and I assume dropped my body and did lots of damage he really didnt care about.
He made some wood frame looked great and one would have expected it to work very well, but perhaps the way he strapped it but my door skins were cracks, rear wheel flares busted rear lower exhaust filler busted, valve covers dented dizzy almost busted off etc etc,
I never got straight answers what happened and the repair he did to the rear flares was horrible and that was the only thing he repaired the rest he didnt care, okay enough of that,
I have been involved with a lot of body lifts and what ever you use to lift just be careful where you place the straps seems that is the key and I do believe that my car was rather extreem all the damage.
PS,
On your screen name my dad was a Navy airplane tech
But my point is more that some corvette shops are worthless and some treat your car like they would their own....
The fellow was a seasoned body man, not a corvette man even though he owned two it didn't make him the expert he thought he was, his ego and lack of being able to communicate was as big a downfall as was his biting off more than he could handle, he wasn't $atan.
it started off very well it took 9 months of games to get to the point of threats of getting the law involved to get my car back....in my case the damage he did wasn't as bad to me as the time he took about 8 months longer than promised....okay enough of that rant,
In my case it would have actually taken more work time money to make what I wanted and not do a body off.
I was desiring a like new car and I wasnt starting with a very well maintained or pampered car.
My build is a great target for all kinds of jabs, if a person raises a flag they should not get upset if that flag gets a salute,
I fully realize my build is too radical for most and many who do like things I'm doing will not tackle it because they are locked into settling with the way their car came factory due to thinking stock is worth more or fear they simply can not pull it off which is hogwash,
No one should settle and if I can make this happen for 13K then any one could.
I admit I do get a bit deflated when it seems that most times here anyone who wants to tackle something bigger than an oil change or God forbid a mod is shot down on the idea.
I've been involved in probably 8 body lifts and the club I belong to uses two stands with a crank on each one. The lifter goes in the door area or rocker lip (really not sure of the terminology). Two people crank to lift the body while others are eyeballing to ensure nothing is still connected. Once the body is high enough, the chassis is rolled out and body dolly is rolled in. The stands have a wide foot base, their made from tube steel. The crank is just like what you would use to pull a boat onto a trailer.
Good luck Bill
I worked in a 13'x22' garage.
I built both a low dolly to move the body around on, and a taller dolly to store the body on so I could work next to it on the chassis restoration.
The body was COMPLETELY bare except for the core support.
The only thing I had plenty of was time; I didn't have much space, money, or skill. But I wanted to do it, so I made it work.
Regards,
Alan
Here the body and chassis are pushed to the end of the garage so I can work in the space across the front of both of them.
Here's the chassis tight against the body dolly with the body pushed forward so I could work across the rear of the chassis and to some degree on each side.
At times I had the chassis on jack stands sitting on casters so I could move the chassis around to get access where I needed it.
I spent 1 or 2 days a month (especially in the beginning) cleaning the garage because I was making so much filth in such a small place I couldn't stand to work in it.
Here's the low dolly. I built both out of wood because I don't know how to weld. There are some really nice aluminum dollies available now but on a budget they're a bit $$ for someone who may only use it once.
I'm handicapped 1980 corvette thankyou
Regards,
Alan
