Leaking flair nuts
I'm replacing the fuel lines at the engine in my 68'. Bought new steel lines ( not stainless) installed them very carefully making sure the line fitted the mating surface. Had to tweak the lines a bit to get them just right with no tension on the line itself. Ha, leak like sieve.
Anybody got a trick to get then to seal. Dealing with gasoline and hot cast iron. Not a good situation.
I am aware of what you have going on and it happens to me. It usually occurs MORE when I am trying to get stainless steel lines to seat.
I verify that the seat in the carb fitting is good and does not have a notch/groove in it due to the line being slightly off when it was put on.
ALSO...when I am putting new lines on with the correct flare wrench...I put it on good and tight...then I loosen it and tighten it back up again and I notice that I get a bit more rotation on the nut when tightening it up. This usually stops the leaks for me. I may have to do this a few times ..but I finally get it...and teh leak stops.
But..the idea that Ed T provided is a good idea!
DUB
I use flaretite inserts on stuborn stainless fittings that won't seal.
Couple of things
Normally I'll tighten, loosen, tighten several times to kind of set the flare to the fitting.
Over-tightening (trying to stop a leak) will frequently distort the tube end and open up the angle so it's trying to seal at the top instead of the side, running the flare tool around it and lightly re-flaring the end will sometimes bring it back.
The other thing is to always put some antiseize on the nut side of the flare so it slips rather than twisting the end of the tube.
Flaretite or the copper inserts work when I give up (usually stainless)
Summit sells some, I think they are Earl's.
Watch the angle, they are available in 37 and 45 deg.
M
Use a good bright light and a magnifying glass to inspect ALL surfaces that are affected during the sealing process (fittings AND line). All should have smooth, clean surfaces. If you find rough areas, you should try to clean them up with sandpaper, polishing paper, stone, etc. If it just won't seal and you purchased those parts from a store or on-line, contact the vendor and explain that the items wouldn't seal; also explain what you tried to fix it. The vendor may send you a new part[s].
The advice in the prior post is good if you find that reasonable tightening will not seal the leak.
Looking at your pics, looks like you have the stock 68 fuel line that screws in and out of the GF 432 fuel filter. Did you change both pieces of fuel line all the way to the fuel pump? Any leaks at the pump or the fuel filter? If it is only at the carb, and it's a big leak, and you purchased the fuel line (so the flares should be well made)..... you may be missing that washer.
Also make sure you don't have 2 plastic washers going into the Quadrajet as they will cause it to leak a lot.
