Radiators
Old Nov 17, 2015 | 05:17 PM
mrichi's Avatar
mrichi
Default Radiators
Iam putting a 454 big block in my 79 Corvette will a Dewitts 74 radiator fit ? I'm using 74 big block top and bottom radiator hoses
Old Nov 17, 2015 | 07:01 PM
DUB's Avatar
DUB
I know GM changed the widths of the radiator cores.. So measuring where the tanks sit in the rubber insulators and checking with DeWitts might be needed to be done.
Not knowing if you plan on using the factory shroud or not....it should work...as long as the tank to core weld seams fit in the insulators as needed.
DUB
Old Nov 17, 2015 | 07:36 PM
mrichi's Avatar
mrichi
DUB
Thanks Dub yes I checked the core widths and the 74 is wider than the 79 by about 1 1/2" so it wont fit at the bottom where it sits on the rubber insulators
To Radiators
