Stamp Pad Question
Old Nov 26, 2015 | 08:16 AM
hzz's Avatar
hzz
Originally Posted by kenba
That is NOT a cast surface. It is broach machine surface. The picture shows lines NOT a sand cast one.
The pad looks good to me...except for the bounced stamp strike, especially when compared to the other pad 22 units away. Pads look similar
Originally Posted by joewill
paint on the pad, hard to read casting date and block casting number, a bounced stamp strike... all attributes that will come up when you try to sell this car a few years down the road... if you buy it...
you just need to buy it at the right price..
if you require the pedigree, then confirm the pedigree before you buy...
if you are looking for a original engine car with no excuses.. this ain't the one. but keep in mind that it is extremely hard to find a car with no excuses at a reasonable price.
That's what's holding me back from buying it....someday when I go to sell, I'll have to answer all the same questions about the block that I am now asking.
What would be a fair price to pay for this car...69 coupe 427 390hp, 4 spd power windows brakes steering and A/C.
No rust on frame or birdcage
A few pics:
Thanks for your opinions, as always
Old Nov 26, 2015 | 11:32 PM
694speed350's Avatar
694speed350
If its a 69 it wouldn't be a 454.
Old Nov 26, 2015 | 11:51 PM
ddawson's Avatar
ddawson
Nope 454 started in 1970.
Old Nov 26, 2015 | 11:55 PM
hzz's Avatar
hzz
Sorry...I corrected error...it's a 427 390hp.
Old Nov 27, 2015 | 12:10 AM
bj1k's Avatar
bj1k
I guess I better get my eyes checked then because I can't see it !
Old Nov 27, 2015 | 12:16 AM
ed427vette's Avatar
ed427vette
The simple fact is it CAN'T be a cast surface. The blocks have to be broached or the heads would not seat correctly on top of the block. Factory broach lines are parallel as the block was cut straight across. If the block was decked latter on it may have circular patterns as most shops have a circular cutter.
Old Nov 27, 2015 | 01:40 AM
ZAKsPop's Avatar
ZAKsPop
Just a completely novice insight but if you were to restamp an engine wouldn't you make sure you do it well enough not to raise suspicion? I would think if this "bounce" occurred at the factory they would be like WGAF but if you were trying to pull one over on someone you would redo it. Just my 2 cents.
Old Nov 27, 2015 | 07:25 AM
ed427vette's Avatar
ed427vette
What you said is true and does make sense...until you see some restamps..... Some are just so bad they are laughable.
However, in this case, I think its a good chance its legit.
