Engine Storage Advice
Old Dec 1, 2015 | 09:32 PM
wheatpj's Avatar
wheatpj
Default Engine Storage Advice
I’m looking for some advice for the preparation and (long-term) storage on my numbers matching engine. The engine with be stored until maybe I sale the car or I decide put it back to a more original condition (and drive it more sensibly). The engine is a 1971 454 LS5. The engine runs strong, but there seem to be some noise from the rotating assemble. I had the oil pan off, which revealed a rod that was rather dark. I will rebuild it when it is put back in service. I plan to block off all the opening, bag it and store it in an engine cradle. Any suggestions for prep and storage are welcomed.
Thanks Pat
Old Dec 2, 2015 | 10:04 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would google long term storage for motors. Boat people call it "fogging the engine" around here. But the engine needs to be running I believe. Its basically an oil base product you spray into the engine as it runs to coat the cylinders in oil as it kills the engine. Basically you're looking to get the cylinders and valves all covered in oil to prevent surface rust. If you have the time just tear down the engine and coat eveything in a rust preventative silicone spray. You could put the block on your stand still and everything else in those vacuum seal bags that they sell for clothes. You suck the air out with a shop vac.
Maybe find one big enough for the whole engine or invent one and become a millionaire. Just remember to slip me a few bucks after you make that first million. Sell them cheap so you sell alot.
Old Dec 2, 2015 | 10:06 AM
Rescue Rogers
http://www.amazon.com/s?ie=UTF8&page...acuum%20Sealer
Old Dec 2, 2015 | 10:12 AM
Richard454's Avatar
Richard454
Back off the rocker arms so the springs are not compressed.
Old Dec 2, 2015 | 12:20 PM
bashcraft's Avatar
bashcraft
The motor needs to be rebuilt. It will need to be bored and most valve train parts replaced. Just plug the intake and exhaust so mice don't get in there and it'll be fine as long as you keep it inside.
Old Dec 2, 2015 | 04:49 PM
mikem350's Avatar
mikem350
To add to the above advice, I have squirted oil in the cylinders, rotated the crank a few times, then replaced the spark plugs. Turn the block upside down, and let all the coolant drain out/evaporate. Or use the block drains if they are not corroded shut.
Old Dec 2, 2015 | 04:55 PM
softwarejanitor's Avatar
softwarejanitor
This is the way people always used to do it back in the day. Drain all the coolant, shoot some oil in each plug hole. Any exposed non-painted metal squirt with some oil or even better smear some bearing grease or cosmoline on if you've got it. Block off all the openings to keep dust and crud out.
Old Dec 2, 2015 | 10:20 PM
sandy laker's Avatar
sandy laker
Run the engine to operating temp using a ethanol free gasoline.
I drain the engine oil while still hot, refill with new oil and new filter. Used oil contains acid that will etch bearings. Run for a few minutes to circulate. I do not drain the anti freeze. I found lots of rust formed inside the coolant passages if left open to air.
I use STA-BIL ® Fogging Oil blown liberally into every nook and cranny of each cylinder...rotating the engine as I do each one. I also loosen every rocker arm although I've been told by more than one knowledgeable mechanic that springs don't go bad simply from being compressed for years. Then I hermetically seal it in a Summit Racing engine bag using my Foodsaver vacuum system.
Old Dec 3, 2015 | 07:22 AM
Redhook98's Avatar
Redhook98
Since it needs a rebuild, simply fog it, drain the coolant and block off all openings as others have suggested. I winterize my boats by just fogging them and making sure the gas has been treated. Simple really.
Old Dec 3, 2015 | 10:25 AM
bashcraft's Avatar
bashcraft
Did you catch the part about the motor needing to be rebuilt?
Old Aug 28, 2020 | 04:32 PM
Dcart1's Avatar
Dcart1
Yes. It does not need a rebuild, just all new gaskets
Old Aug 28, 2020 | 05:03 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Definately seal all the openings regardless. Engine builder friend with 99pt 65 C2 396 had bad overheating problems after fresh 70k restoration.
Nut shells in the water jacket of brand new engine. Was obviously stored for a little while open.
Old Aug 28, 2020 | 09:24 PM
71chimera's Avatar
71chimera
Marvel Mystery Oil is a good fogging oil; so is ATF
Old Aug 28, 2020 | 10:12 PM
bashcraft's Avatar
bashcraft
Anyone know what the current year is?
Old Aug 30, 2020 | 05:33 PM
71chimera's Avatar
71chimera
Year? no different than any year when someone needs motor storage advice
Old Aug 30, 2020 | 11:50 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
I think the post asking about the year came because this is a 5 y/o thread that was brought back to life by a newbie
Old Aug 31, 2020 | 03:48 AM
vettebuyer6369's Avatar
vettebuyer6369
Yep, it’s 5 years old.
To Engine Storage Advice
