78 Connector behind glovebox what for?
Enclosed picture of a plug-in connector when I took out my glove
box there is nothing plugged into it and I cannot find the mating plug also I can't find it in my wiring diagram. Anyone know what this might be for? Thanks for any help.
I believe it is for the light at the top of the Center console
The timing unit is located in that same area (passenger side) but it is an orange box with a small circuit board on the inside.
Hope this helps.
In 1978, RPO ZX2 was a convenience group that included passenger footwell and spare tire lighting. I can check my 78 later (it is still dark out) where I have the interior disassembled and see if the wire color code is same as yours. But I see some electrical tape where there shouldn't be so it leaves it suspect like someone added something. Also check the spare tire area for the light to determine if your model included RPO ZX2. The factory may have included the connector in the harness but not the device (light fixture) if RPO ZX2 was not ordered by the original buyer.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
AM/FM Radio...that connector is not used
AM/FM Stereo...used for right side speakers
AM/FM Stereo with rear speakers...used for rear right side
The glove box is black/orange and the courtesy is orange/white.
I'll bet you get no sound out of your front (or rear) passenger side speaker. It is your passenger side speaker plug...dark blue/light blue. Apparently it depends on your radio type,
also what is this & what does it do?
Thanks for your help the PO sure screwed the Wiring up. Not to mention they glued a Sony stereo radio in the gauge panel, I'll have to cut it out with a Rotary carbide bit.
You were right passenger-side speaker is not working and I have still not found the connector to plug into it, guess I'll take off the speaker grill to help find it, on the timing light that you said its just hanging there what does it do? And I can find no place to bolt it to.
Also what is this & what does it do (the orange box)?
If you have rear speakers, it probably plugs into the rear wire harness assembly that would have dkblue/ltblue wire assembly that routes to the rear of the interior.
The orange box is the courtesy lamp timer. It times out after 30 seconds and the lights go out within the car and at the rear spare tire under the rearend. It usually is taped onto the wiring harness on the passenger side up around the glove box.
