Which adhesive?
Old Dec 12, 2015 | 09:23 PM
croaker's Avatar
croaker
Default Which adhesive?
What to use to hold mirror on ? I used some kinda Permatex on the last one I did fell off after a couple years? What have you guys had success with?
Old Dec 12, 2015 | 09:56 PM
65GGvert's Avatar
65GGvert
I assume you're talking about the inside rear view mirror. I'd try a local glass shop that replaces windshields and ask what they use when they need it.
Old Dec 12, 2015 | 10:44 PM
ballen06's Avatar
ballen06
Epoxy .... but with good surface prep
Old Dec 12, 2015 | 11:18 PM
mikem350's Avatar
mikem350
uhhh...assuming for a glass mounted rear view, maybe not epoxy. If it sticks too good, and you somehow yank on it, possibly destroying the windshield.
Go to auto store or Wallmart get the special Permatex adhesive in the tiny tube.
Old Dec 12, 2015 | 11:55 PM
croaker's Avatar
croaker
Actually I'm inquiring about the outside mirror
Old Dec 13, 2015 | 12:02 PM
ballen06's Avatar
ballen06
rear view mirror is not glass mounted .. at least not in my 69..
Old Dec 13, 2015 | 12:17 PM
pltmgr's Avatar
pltmgr
outside mirror is attached via a door mounted bracket.
Old Dec 13, 2015 | 09:03 PM
croaker's Avatar
croaker
Ok the mirror on the outside of the car mounted on the door needs mirror reattached to housing what glue are you guys using? Thanks in advance
Old Dec 13, 2015 | 09:11 PM
croaker's Avatar
croaker
Old Dec 13, 2015 | 09:41 PM
jim in oregon's Avatar
jim in oregon
A quality double sided thin adhesive pad does fine..3M makes the stuff JUST CLEAN BOTH SURFACES WELL AND DRY..
Old Dec 13, 2015 | 11:03 PM
VETFEVER's Avatar
VETFEVER
Some use silicone - I used an adhesive called "Goop" LoL.
I repaired my wobbly side view mirrors by soaking them in paint thinner until the glass mirror fell off. I eliminated the "looseness" and the mirrors flopping, by slipping a stainless steel washer between the mounting ball and steel strap which holds it in place. It was very difficult to slip the washer into place - I bent two or three attempting it - but when I got one into place it made the ball fit SUPER TIGHT and the mirror no longer droops or is affected by the wind.
Then glued the glass back in place with the "Goop"
vetfever
Old Dec 14, 2015 | 03:01 AM
croaker's Avatar
croaker
Yeah I pressed the rivet tighter. Wasn't much holding it on one side. I did one before but the mirror finally fell out lucky it didn't hit side of car.
Old Dec 14, 2015 | 06:01 AM
7T1vette's Avatar
7T1vette
Ultra Black RTV on the pins that mount up to the backside of the mirror. But, you need to set the front side of the mirror on a tabletop or other horizontal surface so that the mirror does not flex while the adhesive is curing. Then, set the mirror body on top (get creative on how to do that and keep it in place for the cure).
If you just place the mirror down over the pins, the weight of the mirror will cause it to sag (just a tiny bit) as the adhesive cures. In use, you will see a somewhat distorted image.
Old Dec 14, 2015 | 06:42 AM
croaker's Avatar
croaker
I was thinking of using some clamps and wood scraps. So u are saying mirror face down and prop the base . I think I used the Black Permatex on another one and it only lasted a while and let go. What about liquid nails or something like that?
To Which adhesive?
