Weatherstrip adhesive remover?
Old Dec 13, 2015 | 02:43 PM
alconk's Avatar
alconk
Default Weatherstrip adhesive remover?
I need to remove the weatherstrip adhesive before I install new door w/s and want to make sure I'm using the right product. I thought 3M made it but all I can find is adhesive cleaner, is that the same?
Old Dec 13, 2015 | 03:22 PM
Alan 71's Avatar
Alan 71
Hi alc,
The 3M adhesive remover everyone used for years is GONE.
The new 3M Adhesive Remover is 38984.
The 3M Adhesive Cleaner is 08984.
Regards,
Alan
Old Dec 13, 2015 | 03:28 PM
alconk's Avatar
alconk
Originally Posted by Alan 71
Hi alc,
Regards,
Alan
Thank you Alan.
Old Dec 13, 2015 | 03:43 PM
EASYGEAR's Avatar
EASYGEAR
Tar remover worked for me when i renewed the weather seals, i`m removing any adhesives with it.
Maybe you find one in your garage.
If you check the ingredients you will most likely find the same list as in the stuff that is sold as Adhesive cleaner.
Used it on many different paints and surfaces, never had any damage but the adhesives were gone.
Old Dec 13, 2015 | 05:35 PM
SwampeastMike's Avatar
SwampeastMike
I just looked at my cans and realized that I used both "Adhesive Cleaner" and "Adhesive Remover" (3M) when replacing my weatherstripping.
Neither caused any damage to the original lacquer. Both required repeated applications and lots of patience.
Old Dec 13, 2015 | 05:44 PM
Tommy79's Avatar
Tommy79
GOOF OFF... easy to find and cost less than the 3m stuff.
Old Dec 13, 2015 | 10:00 PM
alconk's Avatar
alconk
Thanks guys I'll try the other stuff as well. I believe there are two layers, I can see the yellow under the black unless they just were lazy and didn't get it all.
To Weatherstrip adhesive remover?
