Ignition Coil Replacement 1970 454
Old Dec 28, 2015 | 04:56 AM
PBCloud's Avatar
PBCloud
Default Ignition Coil Replacement 1970 454
The original ignition coil is still working fine (60,000 miles on the clock), do they wear out and need replacing or are the latest ones better for a original 454 engine (10.25 compression ratio with 390 bhp)
If so any recommendations here, otherwise I'll keep it after a little tidying up as it as its a pretty much original car.
Old Dec 28, 2015 | 12:05 PM
mikem350's Avatar
mikem350
Put it on ebay and ask $500...
Seriously, detail it and move on
Old Dec 28, 2015 | 01:27 PM
7T1vette's Avatar
7T1vette
As long as ignition coils remain sealed and never overheated nor experiencing significant over-current conditions, they [OEM units] should last a VERY long time. It is important to match the coil with the needs of your engine (how it is built and how you use it), so the primary and secondary resistances are critical, in this regard.
Just throwing a 'high powered' coil on your engine, so that it COULD have a hotter spark, is a dubious decision, at best.
Old Dec 28, 2015 | 01:54 PM
PBCloud's Avatar
PBCloud
Many thanks I will keep original after restoring it.
Old Apr 9, 2024 | 02:11 PM
jbakyy's Avatar
jbakyy
Off the subject, do I need to retune dwell and timing on my 71 after changing the coil? Thank you
Old Apr 12, 2024 | 11:10 AM
7T1vette's Avatar
7T1vette
No. Ignition coil has nothing to do with the timing. Dwell setting is a 'fine tuning' of the ignition timing due to adjustment of the ignition points.
To Ignition Coil Replacement 1970 454
