removing rear leafs?
Old Dec 10, 2016 | 08:02 PM
  #41
revitup's Avatar
revitup
Originally Posted by DUB
For what it is worth:
I change out rear leaf springs and what I find is the companies are using thicker leafs...regardless of the number of leafs. Which means I need to replace the four bolts to longer bolts where it attaches to the differential cover.
DUB
I noticed the thicker leafs on a replacement 7-leaf I got for my '77. The stack was about 5/8" thicker than the original. Had to put in 1/2" longer mount bolts. I did some research and found out that is common across the board because modern spring steel is rolled out in thicker standard thickness than it was in the past. The spring is supposedly engineered to not cause the car to sit higher, regardless.
