What engine is that?
Old Jan 29, 2016 | 08:26 AM
Proton_ita's Avatar
Proton_ita
Default What engine is that?
Hi Guys, i need just a little help. I've found this '68 with a Chevrolet 350 engine as described. It's clearly a non-matching number, but I'm not able to find out what engine is.
Someone could help me? Many thanks!
http://www.accelautogroup.com/used-c...ls.php?cid=300
Old Jan 29, 2016 | 09:41 AM
Alan 71's Avatar
Alan 71
Hi P,
From the information given and the pictures there's no way to tell what the engine is now or was originally.
It has some aftermarket parts on it ; for instance the intake manifold.
The oil fill is still through the intake which was a 327 method not a 350 method. The change in valve covers could have necessitated that. But???
A picture of the engine's stamp pad MAY help determine WHAT this engine started it's life as.
Regards,
Alan
Old Jan 29, 2016 | 10:01 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
All I can add is that the heads do not have accessory bolt holes in them.....this suggests a pre 1972 engine.....
Even so.....the cylinder head casting numbers would have to be checked against the casting number on the bellhousing boss.
I would kindly ask them if they could provide this info.....and if not....walk away.
Jebby
Old Jan 29, 2016 | 10:20 AM
ed427vette's Avatar
ed427vette
I think the rear valance was replaced because I can not see the reverse lights.
Old Jan 29, 2016 | 10:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Contact the seller and ask about the engine. There should be an engine identification stamp on the pad. FWIW: it has a 68 327 intake manifold installed on it.
Old Jan 29, 2016 | 10:53 AM
Staylor63's Avatar
Staylor63
This car has been for sale for a long time....I have been following it somewhat. I think that in itself is an indication.
Old Jan 29, 2016 | 11:03 AM
Proton_ita's Avatar
Proton_ita
Thank you very much guys, I've asked more informations to the seller
Old Jan 29, 2016 | 11:45 AM
MelWff's Avatar
MelWff
Both rear strut rods are bent.
The AC compressor is missing.
Never use tie wraps to hold the spark plug wires together.
The heater hose on the front of the intake plugged with a fitting, does the heater core have a leak?
Old Jan 29, 2016 | 12:07 PM
Wee's Avatar
Wee
I have no clue if this seller is a supporting member here or not....I will say when I was hunting my 70-72 Vette I looked at quite a few of their ads and came to the conclusion that I would no longer even look at Vette's they had listed.....Just way too many things that smelled of a slimy used car lot. Just look at the undercarriage pics, I've seen better spray can work done by Bubba. JMO and I my get slammed for it but I'm just trying to help a fellow member out.
Brian
Old Jan 29, 2016 | 12:13 PM
Proton_ita's Avatar
Proton_ita
Thanks Wee, in fact I'm very prudent because I don't want to find out that I've payed and shipped a piece of junk across the Atlantic Ocean...
Old Jan 29, 2016 | 12:51 PM
COOLTED's Avatar
COOLTED
Funny how all of the interior pics are a little blurry and the exterior pics are sharp.
Old Jan 29, 2016 | 01:05 PM
Proton_ita's Avatar
Proton_ita
as a photographer for hobby I can understand it, because most automatic digital cameras automatically regulate exposure by brightness. If you shot a black subject the camera automatically set a longer exposure and the photo gets blurry and burned in the less dark details. The white of the body cause less problems because the sensors could detect better the scene brightness level.
That's a pure explanation however, nothing to do with the car or the seller itself
Old Jan 29, 2016 | 03:32 PM
Proton_ita's Avatar
Proton_ita
Response:
Not the matching motor Looks to be stamped T0227HH
Old Jan 29, 2016 | 03:51 PM
Alan 71's Avatar
Alan 71
Hi Pi,
Here are the possibilities:
HH 1965 327 s h/p, m/t 365 4 Vette
HH 1966 327 air inj. reactor 300 4 Vette
HH 1969 350 tur 400 300 4 full size
Regards,
Alan
Old Jan 29, 2016 | 03:54 PM
andrew5's Avatar
andrew5
Default ..
i am always skeptical on a car when i see a (ribbed) style radiator universal hose...
Old Jan 29, 2016 | 04:02 PM
Proton_ita's Avatar
Proton_ita
Thank you Alan I've gived up on this car... still searching for a better Vette!
PS (just wondering... is correct to say "gived up" in that case?)
Old Jan 29, 2016 | 04:05 PM
Alan 71's Avatar
Alan 71
Hi Pi,
I believe….given up on….. would be correct!
Regards,
Alan
To What engine is that?
Old Jan 29, 2016 | 04:56 PM
maverickmk's Avatar
maverickmk
There is also something really funky going on with the oil pan.
Old Jan 29, 2016 | 11:42 PM
Staylor63's Avatar
Staylor63
Right? It looks like someone has beating on it for days with a mallet.
Old Jan 30, 2016 | 08:23 AM
Alan 71's Avatar
Alan 71
Hi,
Perhaps the picture showing the oil pan is an example of one of some 'used Corvette dealer's popular phrases'… car underwent a "high dollar restoration"…. a can of black paint AND ALSO a can of orange paint!
Regards,
Alan
Rectangular and flat… maybe a new jacking point?
