Engine Numbers
Old Feb 16, 2016 | 03:49 PM
veeeight's Avatar
veeeight
Default Engine Numbers
Would anybody be able to help identify an engine in a C3 with the following numbers T5U510266 and 4160VO605TYU
Thanks Phil
Old Feb 16, 2016 | 03:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by veeeight
...Would anybody be able to help identify an engine in a C3 with the following numbers T5U510266 and 4160VO605TYU...
V0605TYU indicates a Chevrolet 350 CID truck engine for 75-77. June 5 (0605) is the day the engine was assembled at the Flint, Michigan engine assembly plant (V). TYU is the engine identification code.
I do not recognize the other numbers although T5U510266 could be a VIN derivative from an assembly plant.
Old Feb 16, 2016 | 04:55 PM
Tom73's Avatar
Tom73
If the engine suffix starts with a "T" it is usually a truck engine. TYU is a 75 van/bus 350.
Tom...
To Engine Numbers
