Heater control valve for '72
Old Feb 23, 2016 | 10:57 PM
kansas123's Avatar
kansas123
Default Heater control valve for '72
I won't presume instructions will come with the purchase of this part, and I was not able to find it in the AIM and the '72 Service Manual so I must ask. Where is the vacuum source for this part and what exactly makes it work? I want to replace the gate valve that I hurriedly installed years ago with the correct application. Thanks
Old Feb 23, 2016 | 11:03 PM
kansas123's Avatar
kansas123
Default Unbelievable
Upon further investigation, this part will only work for 1969 thru 1982, EXCEPT FOR 1972. Oh brother.............
Old Feb 24, 2016 | 07:33 AM
ENCSDOUG's Avatar
ENCSDOUG
I didn't see one when I overhauled the system in my 72. The heater hoses went directly to the heater core.
Old Feb 24, 2016 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I was not able to find it in the AIM and the '72 Service Manual so I must ask...
Some model years did not use a shut off valve. If you do not find it in the AIM, it wasn't used.
Old Feb 24, 2016 | 08:38 AM
7T1vette's Avatar
7T1vette
For vehicles WITH that valve, the vacuum signal to it comes from the little distribution manifold mounted on the left side of the heater control in the lower console. One of those manifold outlets is fed out thru the firewall to control that water shut-off valve.
I'm pretty sure that the A/C vehicles had them, but don't know about the others.
Old Feb 24, 2016 | 08:46 AM
damvette's Avatar
damvette
This is a good option to shut off the water to the car during the summer. I have a 72 with Air and will be interested if you figure out how to make this work for your car.
Derrick
Old Feb 24, 2016 | 09:29 AM
69FASTFUN's Avatar
69FASTFUN
I have a 72 and on the passenger fender well there are two dimples where the shut off valve was mounted previous years. I purchased one and the found out 72 did not use one I guess you could still mount and use it.
Old Feb 24, 2016 | 09:38 AM
damvette's Avatar
damvette
This is interesting that in 71 there was a wh-strip vac-hose per Alan that was used for this valve. But in 72 the vac-hose and valve were removed and do not exist. The design was changed and GM removed it. I'm wondering if it was not effective so GM just removed it all together????
Derrick
Old Feb 24, 2016 | 10:32 AM
DonnieP73's Avatar
DonnieP73
My 73 with air did not come with this shut-off valve.
Heater hoses were solid from core to intake and water pump.
Donnie
Old Feb 24, 2016 | 11:12 AM
CanadaGrant's Avatar
CanadaGrant
I think this is for AC cars only as it would require a shutoff. My 69 BB is non AC and doesn't have one. It sounds like a really good idea for summer but I don't think there is a place to hook it up on the non AC console heater/vent control.
Old Feb 24, 2016 | 11:36 AM
bj1k's Avatar
bj1k
There is none on my 72 either.
Old Feb 24, 2016 | 11:50 AM
damvette's Avatar
damvette
I've not driven my 72-Air car in the summer so I cannot comment on the heat inside. I've only read about how hot these cars are here on this forum.
So is it a MUST to put a manual shutoff valve in the heater core line or do you just go with how GM designed it without one?
thanks Derrick
Old Feb 24, 2016 | 01:45 PM
7T1vette's Avatar
7T1vette
If your car doesn't have a shut-off valve, then you SHOULD add one to cut off hot water flow to the heat exchanger [heater] in times of warm weather. A simple brass in-line ball valve (90* turn lever) will get the job done. You can insert it into either heater hose line running along the right inside fender housing. Putting it near one of the hose hold-down clamps would keep it from moving around. Paint it 'satin' black and no one will even notice it.
Old Feb 24, 2016 | 02:11 PM
damvette's Avatar
damvette
Thanks for the great advise...., lots of value found here in the forum
To Heater control valve for '72
