Removing Rear Spring
Old Feb 27, 2016 | 08:42 PM
Duffeball's Avatar
Duffeball
Default Removing Rear Spring
If I pulled the rear spring and leave the rest of the suspension components. Can I put the car back on the ground without hurting anything? I don't plan to drive it anywhere I just need another set of jack stands before I do my next job.
Old Feb 27, 2016 | 09:24 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I don't think so...you can put a large block of wood under the differential where the spring bolted on and let the car rest on it...don't use a cinder block---they can crush without any warning!
Old Feb 28, 2016 | 09:06 AM
Alan 71's Avatar
Alan 71
Hi D,
If you put the car back on the ground without the spring installed it will go down until the trailing arms hit the rubber bump stops.
I don't know if that happens before or after the crossmember hit's the ground.
The tail pipes, if on the car, will probably hit first.
A couple of 6x6 blocks of wood are a good idea.
Regards,
Alan
To Removing Rear Spring
