Engine Lift Bracket
Old Mar 8, 2016 | 09:47 AM
ballen06's Avatar
ballen06
Default Engine Lift Bracket
1969 corvette L46 with AC
In the M. F. Dobbins book entitled "Fact Book of the 1968-1972 Stingray" it shows photos of the engine with the lift bracket attached.
Is this the proper configuration? I don't see anything in the AIM regarding this bracket.
I bought my car off of the showroom and I don't recall this bracket.
Thanks for clearing this up for me.
Old Mar 8, 2016 | 09:53 AM
Alan 71's Avatar
Alan 71
Hi b,
I'd expect your 69 350/350 to have 2 lift brackets.
One in the left front on an intake manifold bolt and another in the right rear on a bell housing to engine block bolt.
Regards,
Alan
Old Mar 8, 2016 | 10:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ballen06
...I don't see anything in the AIM regarding this bracket...
AIMs show only items/parts which had to be installed by assembly line workers at St. Louis/Bowling Green. Engines were received as assemblies from the respective engine plants (Flint or Tonawanda). The lift brackets were part of those assemblies and were already in place when the engines were received at St. Louis/Bowling Green.
Old Mar 8, 2016 | 11:50 AM
SB64's Avatar
SB64
Default Bracket
Alan is correct that there are 2 brackets the one he show's as well as the front one . Below is the front bracket.
RVZIO
Old Mar 8, 2016 | 12:26 PM
ballen06's Avatar
ballen06
RVZIO
Thanks ... Please tell me how you got your valve covers looking so good.
Mine are blotchy and dull.
Old Mar 8, 2016 | 12:27 PM
ballen06's Avatar
ballen06
Thanks to all.... It looks like I have more stuff to buy.
Thanks again.
Old Mar 8, 2016 | 01:58 PM
SB64's Avatar
SB64
WD40 with 1500 grit wet sandpaper. Then take your favorite aluminum polish and go to town. Takes a little work and time but what doesn't. Hope this helps.
R
Old Mar 8, 2016 | 03:14 PM
xpoc454's Avatar
xpoc454
Wow those brackets are kinda neat. Ive seen the front one before on engines but never noticed the back one. Did they have anything like this on the big blocks of this year ?
Old Mar 8, 2016 | 03:50 PM
steffan's Avatar
steffan
yes big blocks have them too. they are shaped different
Old Mar 8, 2016 | 03:51 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Yup
Old Mar 8, 2016 | 04:01 PM
Alan 71's Avatar
Alan 71
Hi x,
427 engines had the front lifting "eye" EXCEPT for tri-power engines on which it would have interfered with the fuel line manifold located at that point.
I believe the rear lifting "eye" on 427 engines attached to the rear of the right side head….not to the rear engine flange, as sb engines did.
Regards,
Alan
Added:
Hi FR, you beat me with a NICE picture while I was trying to figure out where it mounted on bb engines!!!
Boy! That sucker is pretty!!!
Old Mar 8, 2016 | 05:04 PM
steffan's Avatar
steffan
this may help someone looking to put these on a big block.
small block engines have the intake manifold painted and the bracket would also be painted. certain big blocks have an aluminum intake that would be put on after the block was painted. therefore the bracket would not be painted. makes sense to me but, correct me if I'm wrong here
Old Mar 8, 2016 | 05:25 PM
ed427vette's Avatar
ed427vette
I have seen them painted silver on 69 big blocks or engines that have aluminum manifolds. We were just discussing these in a different thread this past week. Here is a pic.
Old Mar 8, 2016 | 05:50 PM
steffan's Avatar
steffan
interesting, I wouldn't think the factory would have bothered.I see repros in plain steel and zinc plated. for big blocks.no small hole in the front for repros.
I do appreciate the photo as I'm sure others do as well.
Old Mar 8, 2016 | 06:05 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I used diluted hydroflouric acid. Spray on and let sit for ten seconds then hose off with water. Then use some spray nine and scotchbrite pads to clean off the oxidation. This process will bring it back to its natural aluminium look. You could then polish them up but I kinda like the natural look.
Old Mar 8, 2016 | 07:27 PM
ed427vette's Avatar
ed427vette
Not all have the hole. And not all have the part number. The repros are pretty good but they have a horseshoe stamp that they claim is correct. I have never seen an original with the horseshoe stamp. Also there are a few repro companies making them. Some of them are completely incorrect.
I have one on a 69 427/390 that does not have the hole or number stamp but the car is pretty much untouched and I'm convinced its original. But I have seen what I believed were original cars that did have the hole and number. If you look in Dobbins book which was printed before they made repros of the brackets you will see pictures of them with a small hole. Also I'm not sure all were painted silver. I've seen some painted orange as well as silver. And I'm not sure all of what I've seen was completely original. With that said, I can't say for sure what they really did with consistency back then and if they had a standard approach as to what was done with the brackets except to use them to drop the motor in the car.
Old Mar 8, 2016 | 08:58 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Here's an original aluminum intake LT -1, they weren't painted all nice and pretty like the restorers make them.....Keep in mind, get the car down the line.
To Engine Lift Bracket
Old Mar 9, 2016 | 07:58 AM
Faster Rat's Avatar
Faster Rat
[QUOTE=Alan 71;1591727785]Hi FR, you beat me with a NICE picture while I was trying to figure out where it mounted on bb engines!!!/QUOTE]
Only chance I have is to wait for a '69 BB question. You have all the rest pretty much covered.
Old Mar 9, 2016 | 09:49 AM
Don Rickles
2017 C3 of Year
Faster rat,
What are you looking for? I can check on my '71BB?
Old Mar 9, 2016 | 11:46 AM
Faster Rat's Avatar
Faster Rat
Originally Posted by War Bonnet
Faster rat,
Nothing. I was just complimenting Alan about him being so quick to the draw.
