Storage behind the seats
The middle and battery compartment lids are nearly impossible to open. Are there any known fixes I can do to make opening an closing them with the button easier?
If the door is open and you press the button does it work then? Can you see the little dog retract into the cylinder etc?
If it works fine with the door open, the catches on the floor might be adjusted wrong.
They are slotted and if they are set too close to the cylinders on the doors they might be still touching some when the button is press.
If the buttons are hard to press when the door is open, I'd remove the screw from the underside and take the cylinders out, clean them, maybe soak in some valsol overnight and then oil / penetrant and work them free,
Just a couple of ideas
M
closes. You can adjust them in or out as they have slotted screw holes.
You can see what they look like on this link.
http://www.corvettemods.com/assets/images/602469.jpg
Hope this might help.
Donnie
Donnie
The issue is that they will not open without force.
The cylinder operates as designed.
I didn't know the striker was adjustable, so I'll give that a go!
Have you lubed the hinges? The original ones were unpainted steel, and often rusted, making them hard to open. Repro hinges are stainless steel, lessening the likely hood that they will rust.
What year are you dealing with?
68's had a hinge with a spring built into it, that was supposed to pop the door open, when the buttons were pushed. They didn't work as hoped, so for 69, GM added vinyl loops to each door, to pull the door open with. The vinyl loops were used until 77, when they were replaced with metal tabs.
If you don't have the loops, the doors are almost impossible to open. If you have a 68, it pays to add the loops to the doors, unless you're doing an NCRS correct restoration.
There are after market "springs" available, to help open the compartment doors. They're not a spring in the traditional sense, but instead are spring steel tabs, that assist in popping the doors open. The set of 3 runs about $10.
The battery compartment was fixed with just loosening the screws and moving the striker back a bit.
The center compartment required some dremelling to make the range of adjustment a hair more. This one was missing the leather loop so I made one out of my wife's old black leather purse
Thanks for the tech-tips.
You guys
