shifter locating gauge
Old Mar 13, 2016 | 03:36 PM
Omarsvette's Avatar
Omarsvette
Default shifter locating gauge
this tool locates the shifter in neutral. once everything is connected do you remove the tool or leave it in? sounds like a dumb question right.
Old Mar 13, 2016 | 03:38 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
For a stock Muncie shifter you must remove the tool after you adjust the linkage.
Old Mar 13, 2016 | 10:54 PM
Omarsvette's Avatar
Omarsvette
my shifter is very rough on shifting like the shifter links are corse feeling.cant get into reverse also. tranny is new and can be shifted by hand fine. i can connect the links and it will shift. when not connected the shifter moves fine, just rough when linkage is connected.
Old Mar 14, 2016 | 09:38 AM
bj1k's Avatar
bj1k
Yes , it is just for alignment of the shifter arms . If it is the plastic ones grease it before installing it to make it easier to remove . The plastic tends to stick.
Old Mar 14, 2016 | 02:07 PM
MelWff's Avatar
MelWff
are you aware that since reverse in not synchronized it states in the owners manual you should engage a forward gear before attempting to shift into reverse. When you replaced/rebuilt the transmission did you disassemble, clean, and lubricate the shifter?
To shifter locating gauge
