Car will not start
Old Mar 22, 2016 | 01:14 PM
ballen06's Avatar
ballen06
Default Car will not start
1969 corvette L46 with AC
All I get when I turn the key is a soft metallic sound (relay?)
I am getting no voltage across the neutral safety switch.. so obviously no voltage to the starter.
Also I get no buzz from the horn relay.
Where do I go from here?
Thanks for your help.
Old Mar 22, 2016 | 01:32 PM
John485garage's Avatar
John485garage
ballen06
What is your battery voltage? should be around 12.5 volts, no load.
If ok, start checking your fuses.
good luck
Old Mar 22, 2016 | 02:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree with John485. Sounds like battery to me.
Old Mar 22, 2016 | 04:17 PM
ballen06's Avatar
ballen06
Battery measures over 13V .. no load.
Can someone provide me with a starting circuit diagram?
Old Mar 23, 2016 | 06:11 AM
ballen06's Avatar
ballen06
My hood is off. Is there a theft deterrent relay I should be concerned with?
Any other ideas as far as trouble shooting.. I'm lost right now.
Old Mar 23, 2016 | 06:15 AM
Tooonz's Avatar
Tooonz
How about the starter solenoid?
Old Mar 23, 2016 | 06:36 AM
Phillip123's Avatar
Phillip123
Sounds dumb but what is the voltage on your battery?
Old Mar 23, 2016 | 07:55 AM
ballen06's Avatar
ballen06
Over 13V unloaded... I'm not sure if that tells me I have a good battery.
Old Mar 23, 2016 | 08:05 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Put it in nuetral and try again.
You need to start at the furthest point away from the battery with the key on and keep checking power til you find it. Your ignition switch could be a problem too
Old Mar 23, 2016 | 08:23 AM
ballen06's Avatar
ballen06
With the key in the start mode (or accessory mode)? sorry .. I'm a stupid mechanical guy.
Old Mar 23, 2016 | 08:27 AM
Redhook98's Avatar
Redhook98
You checked your battery voltage at the battery, but did you check your battery cable connection? Check that voltage at your alternator or starter to see if the battery cable is making a good connection. Often times with a bad battery connection, you will see 12+ volts in your accessories and at your starter until you turn the key. Then it goes "click" and dies. Did it just start doing this?
As for the neutral safety switch, you can jumper that to eliminate it. Sounds like a bad battery cable or connection to me.
Old Mar 23, 2016 | 09:12 AM
ballen06's Avatar
ballen06
OK.. Thanks.. I will jump the nuetral safety switch.. and yes I do just get a muted metallic click when I turn the key to start.. I'll check my battery connections.
Since I am by myself it is hard to check voltages when the key is in the start position ...
Old Mar 23, 2016 | 09:25 AM
65GGvert's Avatar
65GGvert
It could very easily be the solenoid itself. I'm not sure what you mean by no buzzing from the horn relay
Old Mar 23, 2016 | 10:05 AM
ballen06's Avatar
ballen06
I guess I'm referring to the key buzzer ... not getting that noise.. I was thinking it came out of the horn relay for some strange reason.
Old Mar 23, 2016 | 10:43 AM
Rescue Rogers
my 68 horn relay acts as the buzzer with the key in but not in acc or on positions
Old Mar 23, 2016 | 01:30 PM
The Punisher's Avatar
The Punisher
Anything else not working? Lights, horn,radio,etc.
Old Mar 23, 2016 | 02:42 PM
mickey5's Avatar
mickey5
Pull on the headlights and turn the key to start. If the lights start out bright and go dim with key start actuated, its either a bad battery or a short in the starter...badly worn brushes?
To Car will not start
Old Mar 23, 2016 | 03:21 PM
ballen06's Avatar
ballen06
Interior is not in completely as yet..so can't check radio
interior lights come on..horn makes a pitiful sound.. headlights come on.
Old Mar 23, 2016 | 03:34 PM
65GGvert's Avatar
65GGvert
Just to check connections, hook the positive meter lead to the starter lead and the negative to the frame of engine (not across the battery) and turn the key to start. How low does the voltage drop when you do that?
Old Mar 23, 2016 | 04:02 PM
The Punisher
with the headlights on and you turn the key do the headlights dim or go completely out. If they do its usually a grounding issue
