What Plating
Old Mar 23, 2016 | 11:04 PM
71frameoff's Avatar
71frameoff
Default What Plating
1971 removable rear window. I would like to have the frame refinished. what is it??
Old Mar 24, 2016 | 01:51 AM
13611's Avatar
13611
Old Mar 24, 2016 | 02:59 AM
Haggisbash's Avatar
Haggisbash
Looks like it is anodised to me.
Old Mar 24, 2016 | 07:48 AM
Alan 71's Avatar
Alan 71
Hi 71,
I think H is right.
It appears to be extruded aluminum that has been clear anodized.
So it's similar to the the rocker trim panels.
Regards,
Alan
Old Mar 26, 2016 | 07:29 PM
71frameoff's Avatar
71frameoff
Originally Posted by Alan 71
Hi 71,
I think H is right.
Regards,
Alan
Thanks to all!!
now, how to remove the ugly stuff and get it recoated. maybe sand it off then polish and then reanodize???
Old Mar 27, 2016 | 07:37 AM
Alan 71's Avatar
Alan 71
Hi 71,
I'd make sure you have someone lined up who is able and is willing to do the anodizing on the frame pieces before you begin restoring the surface.
Regards,
Alan
Old Mar 27, 2016 | 12:04 PM
mickey5's Avatar
mickey5
A forum member on another thread suggested stripping anodize by immersing the part in a container of water and adding Draino crystals (not liquid). Don't leave it in too long as it will attack the aluminum.
Trying to remove anodize with sandpaper is difficult at best as the coating is very hard.
If you locate a plater willing to take in a small anodize job it would be better to let them do the stripping and bright dip.
Old Mar 27, 2016 | 07:00 PM
Mooser's Avatar
Mooser
I'm the drano guy
If you do take them to a plater for strip / anodize, make sure they are used to (old) automotive parts.
I once took some parts to a plating house we used (aerospace) for years, older guy that owned the place has been plating (anodize, cad, zinc, black-oxide etc) forever.
Melted the crap out of both parts during the reverse etching.
Our parts are amazingly soft compared to what a commercial shop does day to day.
Since then I strip my own parts. Small parts I anodize here, larger parts go out
M
Old Mar 27, 2016 | 07:55 PM
BarryB72's Avatar
BarryB72
I got a spare rear window off of ebay and it had a decent gouge in the frame from im guessing the screw that holds the latch in the window tray. I wanted to smooth out the frame around the gouge and realized after I took a few swipes that the place I sand would look ok but the periphery of the area looked white - as if there was a layer of white paint under a silver layer - the plating I'm assuming. Only solution was to go ahead and sand the entire lower frame section. I used 400 and yes it took awhile to get through all the layers of plating, but once I did I was able to polish it and put some fine lines that kind of mimicked the original look with some steel wool. It's much more susceptible to light scratches that show but I can always take some steel wool and clean it back up - kind of how I do with my sill plates. I do not notice a difference between the sanded lower section and the unsanded upper section when the window is in the car
Old Mar 28, 2016 | 03:31 PM
71frameoff's Avatar
71frameoff
thanks! does anyone sell a new frame??
Old Mar 28, 2016 | 04:01 PM
BarryB72's Avatar
BarryB72
That's a big fat no.
I almost broke google i was on it so much looking for one. i found one on chicago corvette supply's website so I (thought I) bought one from them. Weeks went by and it never showed up. They said it was coming from a vendor in California and they were busy getting ready for Carlisle, then they were at Carlisle, then they weren't back from Carlisle, then they hadn't finished unpacking from Carlisle. Then one day there's a big box on the porch. Open it up...rear window chrome from a I don't know what year. Called Chicago Corvette for the fifth time and the guy says "that 's what you ordered". I said "no, I ordered the removable window frame". He said, "oh, we're out of stock".
Just checked. It's still on their website for $295. Maybe they've found one since then. If not, you will get your money back - eventually.
You'll get a hit on Willcox as well, but at least their site says out of stock.
Old Mar 28, 2016 | 04:58 PM
71frameoff's Avatar
71frameoff
I talked to a local plating shop. they said that the stripping process is very important because if not done properly is will cause dark spots when re-anodized. the anodizing darkens the alum so it has to be polished before anodizing. so around $150 to strip and anodize and $100 to properly polish. and hopefully they don't destroy the frame!! maybe just have it chromed, I know, hard to chrome alum
Old Mar 29, 2016 | 02:29 AM
7T1vette's Avatar
7T1vette
Probably less money to buy a new window frame. Or you might find a decent used one at a Corvette swap meet.
To What Plating
