Original paint?
Old Mar 25, 2016 | 07:07 AM
BoatDaze's Avatar
BoatDaze
Cruising
Default Original paint?
When did GM start using clear coat? I just bought a 1970 that was supposed to be original paint. Even though there is quite a bit of lacquer checking in the paint job it appears glossy as if it was clear coated. The seller insists he had the car looked at by NCRS guys and they felt it was original, but it seems too "glossy" to be original.
Thoughts?
Old Mar 25, 2016 | 07:23 AM
fishslayer143's Avatar
fishslayer143
easy to check.... use a little lite compound or even a cleaner wax on a white rag , rub the surface for a few seconds , look at the rag...is it the color of your car? if not, ITS CLEAR COATED .. By the way, Acrylic Lacquer, properly polished can have quite a gloss even without clearcoat
Old Mar 25, 2016 | 07:39 AM
BoatDaze's Avatar
BoatDaze
Cruising
I did try that last night and the rag did not pick up the color of the car.
Old Mar 25, 2016 | 08:08 AM
Alan 71's Avatar
Alan 71
Hi bd,
Your 70 originally had a acrylic lacquer on it with no sort of clear sprayed on top of it.
Even the original lacquer paint on your car can still be polished to a high gloss…. it's the nature of acrylic lacquer…. if there's paint there, it can be made to shine.
If you did not pick up any color when you tested I'd say at least that area of the car has some clear on it.
On my car even a quick rub with Swirl Remover produces a bit of color on the cloth.
Regards,
Alan
Old Mar 25, 2016 | 08:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BoatDaze
...When did GM start using clear coat?...
Model year 1981 at Bowling Green. All St. Louis cars were acrylic lacquer without clear coats including the 81s built at St. Louis.
Old Mar 25, 2016 | 09:48 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
when parked inside with artificial light pointed at it. is the reflection clear or fuzzy
Old Mar 25, 2016 | 05:33 PM
mikelj's Avatar
mikelj
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
+1, like my early BG car, last carb, first CC.
Old Mar 25, 2016 | 10:44 PM
gbvette62's Avatar
gbvette62
St Louis didn't have the ability to do a two stage paint finish, which was part of the reason for building the new plant in Bowling Green.
I have an 81 Bowling Green car, that I bought new. Back in 81, the difference in the finish of an 81 Bowling Green car, when parked next to a St. Louis car, was striking. The shine and the actual finish of the paint, was amazing, when compared to the St. Louis finish. The door jams on Bowling Green cars, had a better shine, than the body did on the later St. Louis cars.
Old Mar 26, 2016 | 04:38 AM
hunt4cleanair's Avatar
hunt4cleanair
The seller insists he had the car looked at by NCRS guys and they felt it was original, but it seems too "glossy" to be original?
And afterward had it clear coated!
Old Mar 26, 2016 | 05:10 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
What color is it
Old Mar 26, 2016 | 09:22 AM
CV62Air's Avatar
CV62Air
Originally Posted by fishslayer143
... By the way, Acrylic Lacquer, properly polished can have quite a gloss even without clearcoat
Damn Skippy! Love the look of highly polished lacquer!
Also, great color combo on your '81, mikelj
Old Mar 26, 2016 | 10:16 AM
fishslayer143
Then it is clearcoated ..or some type of sealant has been applied ..Acrylic Lacquer oxidizes and small amount of color will come off on the cloth..
Old Mar 26, 2016 | 10:21 AM
71 Green 454's Avatar
71 Green 454
Could be.....
Many years ago, I met a Corvette owner at a car show and I commented how shiny his paint looked. I thought he had repainted the car, but he stated he sprayed a clear coat over the original lacquer.
To Original paint?
