I got a problem with a mechanic who is rebuilding my engine, it's a L-46 350-350 1969. he told me I had the wrong Harmonic Balancer on my car yet it was #3896966? Isn't that the original GM #. Sometimes it stinks being a women in a dominant mans profession because they don't want to listen. He did not believe the car was built in December of 1969 even after I proved it. Said he has a corvette guy who knows all about corvettes and they where all built months before they actually came out.
Now I am worried that he doesn't know as much as he states, so what's a girl to do? I don't want to argue with him about all my parts. So I thought if I gave him actual GM parts list maybe that would help. What do you guy's think?
Here's a little info.
Found this after a quick Google search http://www.ncrs.org/forums/archive/i...p/t-96109.html
It's a lot easier these days to find information witht the intrest net and all. Back in the day I remember you had to rely on your circle of friends.
Was that you at a machine shop in Gilbert last week??
EXACTLY what you are doing right now....so that makes you SMART!!!!
Asking for detailed info will aid you in your 'battle' to prove your point. And this statement is coming form a guy who owns his own Corvette shop. SO...do not be afraid to stand your ground when you know you are right. Because I do it with my customers when I know I am right.
I do have to agree with how so many parts that were dated came into the plant prior to the assembly of the car. That is a fact and can be proven. Such as you date codes on all the glass in your car ...many have different dates PRIOR to the build date of your car.
I can not do it right now because I am at home and my books are at work...BUT...if this is not resolved with the information in the previous post to you liking...I can check and see what I can find and post it tomorrow....and.....sometimes when GM had plant shut downs and or strikes in the labor force....I do not know how much that effects things.
Do you have the original numbers for Harmonic Balancer?
Not off hand, i will grab a flashlight tommorow and see if i can find stamp.
If it's stamped on outer edge like timing line i may be able to help. I'll let you know tommorow.
My car has a 34,xxx vin number i dont know how close to yours.
Good luck
I looked in my GM parts book. And the part number you listed ...3896966...DID NOT show up in the part book. And this GM parts books last revision was back in 1983.
I KNEW there was a STRIKE somewhere during that era...just did not know exactly when.
I may be wrong.....but for the longest time...I always thought and have been told that a 400 cid is externally balanced...so the harmonic balancer is different...but a harmonic dampener is the same for a 350 cid....except for some diameter differences.
I can take a photo of the page form the GM part book and post it.
This post reminded me of a similar concern I had when I built my 383 from a Gen I 350. We internally balanced the components, and I bought this GM balancer P/N 88960604, which was advertised as a direct replacement for Hi-Performance Small Blocks. (302, LT-1, L-82 etc) But for some reason, I ended up going with an aftermarket balancer. I do not have a clue at the moment why I switched, but as I understand it, Gen II blocks with one piece rear seals and all were externally balanced? Indeed the ZZ4, ZZ383 crate engines are externally balanced. However it appears GM considers the currently available balancers to be interchangeable between old and new? Not sure what other conclusion to reach at this point.
I have the 88960604 unit brand new in the GM box if anyone is interested.
DUB
The 400 cid IS externally balanced. The flex plate has a piece of iron welded to it for the balance. You can use a 350 flywheel but need a balance plate with it. I just went through it when I converted to a Tremec 5 speed. I forgot about the balance and had to pull the transmission back out to install the balance plate.
Thanks guy's for your time and effort. It looks like 3896966 is the correct balancer so I will stick with that. It's also the Muncie 4 speed. the engine and tranny are all original and don't want to change anything there. Appreciate all the unfo.
As I mentioned...and you do as you wish....but that number is NOT in the GM parts manual fora Corvette. I am assuming that the car you are working on is a Corvette and not a Camaro....because L46 is not en engine option code for a 1969 Camaro.???
There was a balancer back about that time that was listed in the Chevy Power Catalog. Don't recall the number, but it was listed as an 8" nodular iron and was heavier than the stock one. I've still got it on the front of a 355.
Ahh the confusion.. Took me some time to sort all this out a while back.
All Gen I 2 piece RMS 350's are INTERNALLY balanced.
All 400's are EXTERNALLY balanced.
1 Piece rear main seal SBC are still considered Gen I. They ARE referred to as external balance or internal/external but, they are not the same as a 400. They are technically INTERNALLY balanced, however the counterweight / flywheel & flexplate flange that is on the outside of the main seal on a 2 piece rear main seal crank, is not there on a 1 piece RMS crank. So, that weight is located on the flywheel / flexplate. The balancer is the same / neutral as a 2 pc RMS block and not used for balancing.
The original balancer for a '69 350/350 (L46) was p/n 6272224, which is now obsolete. It was also used on the LT-1, L82, and Z28.
The balancer on mine failed and I replaced it with 88960604, which, as mentioned above, is for a ZZ4 etc, engine.
The only difference is the 88960604 has an embossment of degree marks around about 90 degrees of the perimeter of the ring. A cosmetic thing that has no bearing on the look or operation.
I know the 88960604 fits/looks and works well on mine.
