leaf spring liners
Old May 5, 2018 | 11:56 AM
  #41
Jim71Vette's Avatar
Jim71Vette
Default And....what about the bolt?
Originally Posted by teamo
Here is the finished spring. I need to trim the spring liners a little and it will be finished. I also cleaned and painted the driveshaft in the same gray color. I've got things back in full gear since the winter break so I am continuing on with painting parts and will start re-assembly of the rear suspension soon. I had a lot of parts all blasted and ready to paint but they flash rusted from sitting over the winter. I re-blasted them today. Didn't take very long as there was only a light coating of rust. I am going to get a coat of Eastwood Epoxy Primer on them and then top coat them.
Is locktite sufficient for the nut when assembed? Maybe peen the bolt?
I wouldn't want to be driving the car if the nut backed off.
Old May 5, 2018 | 08:17 PM
  #42
teamo's Avatar
teamo
I was thinking locktite and possibly use two nuts and tighten them together such as with a parking brake equalizer (two nuts tightening against each other).
Old Jan 3, 2019 | 08:53 AM
  #43
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Hey Teamo,
I am going to restore my leaf springs this winter. Where did you get your liners? I have a 1980 but it doesn't seem the main shops have a set that goes to that year.
I also saw this on ebay: https://www.ebay.com/itm/Leaf-Spring...YRm5:rk:5:pf:0
Also, using the anti-seize...did you put that on the top and bottom of the liner so both leafs slide? Would you recommend something else for this since it is metal on plastic?
Old Jan 3, 2019 | 01:41 PM
  #44
teamo's Avatar
teamo
I got the liners from Corvette Central. They had two liner kits if I remember correctly, with one kit (the one that I bought) having the liners cut to size. I brushed on a light coating of copper anti-seize between each liner top and bottom. I've read where some people have used a graphite powder on the liners which would probably be a better choice. I think that the liner in the link would work well also, as long as it's the correct width for your spring.
Old Jan 7, 2019 | 01:48 PM
  #45
~Stingray's Avatar
~Stingray
The lines from ebay are 2.25 and i think the 1980 are 2.5inches, so those won't work.
