Again, A Tire Size Question
Old May 24, 2016 | 10:56 AM
madam's Avatar
madam
Default Again, A Tire Size Question
In a 27 inch diameter tire (or close to it), what is the widest tire size that can be mounted on the rear of 1976 w/stock 15 inch ralleys??
If I would need to relocate the e-brake cable no problem.
Thanks guys,
Mike.
Old May 24, 2016 | 01:38 PM
gbvette62's Avatar
gbvette62
The factory put 255/60R15's on 78-82's, which are about 27" diameter. A 275/60R15 is about an inch taller, and a 295/50R15 comes in just a little shorter at about 26.7".
The 295/50 is a little over an inch wider in the tread than the 255/60, and has a section width 2 inches wider. The tread width shouldn't be an issue, but the section width might cause interference with the spring ends or parking brake cable brackets.
Old May 24, 2016 | 10:31 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I personally wouldn't recommend wider than the 255/60s on stock 8" wide rally's though. The 255's are already reasonably wide for an 8" rim. You can certainly fit wider, but they will look puffy on the wheel and will flex a lot in corners.
Old May 25, 2016 | 09:06 AM
74Ken's Avatar
74Ken
I assume 75 is the same as the 74.
You can mount a 295/50 on a 8" rim, but that would be puffy.
I went with 255/60's on the front and 275/60's on the back.
Both wheel wells are nicely fitted.
To Again, A Tire Size Question
