Th 400
Old May 28, 2016 | 08:54 PM
POLICE COPTER's Avatar
POLICE COPTER
Default Th 400
I have discovered my 71 TH 400 Transmission is in need of an overhaul or replacement. Looking at Summit and Jegs rebuilt units.....want to spend about $1500 or less. Any advice or experiences with these transmissions?
Old May 28, 2016 | 10:38 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I wouldn't know about those vendor's transmissions.......I have bought other parts from them that are quality parts. If you are able to turn wrenches you can buy a very good rebuild book with illustrations to rebuild your TH400. You would have to disassemble your trans. completely to make sure no major damaged has been done......then buy a quality rebuild kit and do the work yourself.
A new torque converter would be a good choice also to prevent contaminating your new/rebuilt transmission.
Wait for experienced members to reply.
Old May 28, 2016 | 10:39 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Take it to a local trans shop in your town and ask them about doing a rebuild.
Old May 28, 2016 | 10:54 PM
The13Bats's Avatar
The13Bats
Not sure you can do it for 1500 likely no, but you might consider if you drive the car much a 4 speed automatic, with overdrive it's a whole new creature
Old May 29, 2016 | 08:49 AM
GUSTO14's Avatar
GUSTO14
While the Turbo 400 was an excellent transmission back in the day (and still can be of course) the addition of an overdrive transmission may well bring a new level of enjoyment to you Corvette. There are a couple of threads regarding swapping out for an overdrive automatic in the C3 Tech/Performance Forum going on right now.
Good luck... GUSTO
Old May 29, 2016 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Take it to a local trans shop in your town and ask them about doing a rebuild...
Or do it yourself. I did.
Old May 29, 2016 | 10:47 AM
rosslato's Avatar
rosslato
What State are you in?
Old May 29, 2016 | 10:58 AM
Mikeski's Avatar
Mikeski
I agree with GUSTO14. Get a rebuilt auto with overdrive. This website has two that are within your budget. http://www.monstertransmission.com/H...on_c_4044.html
Old May 29, 2016 | 12:09 PM
7T1vette's Avatar
7T1vette
If you want to keep your car with the 'original' equipment, have a local trans shop rebuild YOUR transmission (don't 'exchange' it). If you don't care about originality, swap your THM-400 out for a THM-200R4 overdrive unit. That may run you up to the $1500 you have, but it will be SOOooo much easier on the engine, quieter, smoother, and more economical than that old gas-guzzling 3-speed auto trans. Nothing wrong with the THM-400…it's super durable; but it is very inefficient and doesn't offer you an overdrive range nor a lockup clutch.
I made the change and I love it. Great for highway driving (2100 rpm @ 70mph).
Old May 29, 2016 | 05:41 PM
POLICE COPTER
Texas...near Austin
Old May 29, 2016 | 10:17 PM
mrvette's Avatar
mrvette
My '72 vert was a Muncie 4 speed, and in the DC region I shifted from 2nd to 4th in traffic....yes it was that bad.....3rd was rarely used 350 engine 336 rear ratio......
here in Florida a couple years later it was OVERdrive or fuggetaboutit.....so in went a 700 which is a poor match to the car....so went over to a 200 4r that I rebuilt myself with Trans Go shift kit and good quality soft parts.....mounts with stock driveshaft, but you will need a new cross piece and smaller output yoke.....like fits a thm350
I had to widen the tunnel on pass side, but it was a slim Muncie car so doubtful you will need do that.....
Old May 29, 2016 | 11:06 PM
gkz's Avatar
gkz
B&M makes a rebuild kit with kindergarten instructions. I'm not a pro and I rebuilt mine. The hub seals were the hardest things to install, but it went all right. Shifts tight.
http://www.summitracing.com/parts/bmm-20229/overview/
Old May 30, 2016 | 06:50 PM
POLICE COPTER
Default th400
just wanted to thank you regarding your heads-up about Monster Transmission....looks like the best way to go for my 71 a rebuilt th400 for about $1300 with a good warranty. it has a new stroked 383 in it and it sounds good but the transmission needs attention now. will let you know how it works out thanks again.
Regards,
Police Copter
Old May 30, 2016 | 11:16 PM
The13Bats's Avatar
The13Bats
Regards,
Police Copter
I'm lost are you going with a rebuild of your th400 3 speed or the 4 speed auto od as in the link above?
Old May 31, 2016 | 07:29 PM
POLICE COPTER
I am staying with the Th400
To Th 400
