68 rear light wiring harness
Old May 30, 2016 | 02:39 PM
gbonsal's Avatar
gbonsal
Default 68 rear light wiring harness
Looks like I need to replace the rear lamp wiring harness. What's the best way of going about it?
Old May 30, 2016 | 04:20 PM
Rodney Slavin's Avatar
Rodney Slavin
Are you wanting to buy a new harness or a working undamaged original harness?
Old May 30, 2016 | 06:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There isn't much to replacing the rear harness, the muffler is kind of in the way.
It unplugs right behind the kick panel and the hardest part is getting the heavy grommet in place at the rear of the car.
https://willcoxcorvette.com/corvette...r-optics-68-68
This harness is eligible for the 15 off code from our current sale.
https://www.corvetteforum.com/forums...e-savings.html
Willcox
Old May 30, 2016 | 06:34 PM
Alan 71's Avatar
Alan 71
Hi,
The interior needs to come apart a bit to get the old harness out and the new one in.
The kick panel, the sill plate, and the quarter trim. The floor carpet and the rear wheel well carpet need to be lifted a little but not removed.
The glove box light is part of the rear harness so the piece of carpet on the bulkhead behind the seats needs to be lifted too.
The ground connections for each rear lamp is on the lamp housing mounting studs. You need to be careful you don't twist the stud off when loosening the nuts.
All the connectors, clips and screws/nuts need to be handled gently since they're likely elderly.
Good Luck!
Regards,
Alan
Old May 31, 2016 | 07:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Looks like I need to replace the rear lamp wiring harness...
Why? Is it cut/damaged? FWIW: my 68 still has the original harness.
Have you cleaned the grounds?
Old May 31, 2016 | 11:49 AM
gbonsal's Avatar
gbonsal
I am going to buy a new one. Probably better that way
Old May 31, 2016 | 11:50 AM
gbonsal's Avatar
gbonsal
Old May 31, 2016 | 11:55 AM
gbonsal's Avatar
gbonsal
Default 68 rear lamp wiring harness
Sorry but I am having a struggle figuring out how to reply back to all the kind people who have responded to my question regarding rear lamp harness. All of you replies have been extremely helpful.
Old May 31, 2016 | 11:57 AM
gbonsal's Avatar
gbonsal
The question from Easy Mike - the reason I am looking into replacing the rear harness is that I am blowing brake switches. So I'm thinking I have a bad wire somewhere along the line.
Old May 31, 2016 | 12:02 PM
gbonsal's Avatar
gbonsal
Yeh the ground have been cleaned. I'm going through break switches so I'm thinking the problem may be somewhere in the harness.
Old Jun 1, 2016 | 02:45 PM
gbonsal's Avatar
gbonsal
Willcox
What company manufactures your harnesses
Old Jun 1, 2016 | 04:01 PM
0Willcox Corvette
Former Vendor
Lectric Limited.. All of them. And they are the only brand I will install in my shop.
Willcox
Old Jun 1, 2016 | 04:59 PM
gbonsal's Avatar
gbonsal
Willcox
Perfect. I will be placing an order through you for the harness and a couple of other items. Much appreciated.
Old Jun 1, 2016 | 09:39 PM
0Willcox Corvette
Former Vendor
Old Jun 20, 2016 | 02:20 PM
gbonsal's Avatar
gbonsal
Default Help!!!!!!
You had replied to my initial query regarding rear lamp harness for a 68. I need more help. I tested the rear harness and it showed no breaks or problems as I had power going to the rear lights. The break lights are now working as are the tail lights, but now the signal lights do not work. When I turn the signal light on, the lights go off.
I am hesitant to buy the rear lamp harness if that is not where the problem is. Could I have now blown the turn signal switch?
Old Jun 21, 2016 | 08:56 PM
loup68's Avatar
loup68
Army
Believe it or not, the turn signal switch controls all of the rear lights. I had no brake lights and Willcox helped me out. It was the turn signal switch. Lou...44 year 68 coupe owner.
Old Jun 8, 2023 | 11:17 AM
ariellelapierre's Avatar
ariellelapierre
Originally Posted by Alan 71
Hi,
Good Luck!
Regards,
Alan
Hi,
I know this tread is a bit older, but I have replaced the rear wiring harness and am having an issue with the brake lights not working.
I took the old one out because it was really deteriorating, wires were just falling apart.
The nuts on all my rear lights were so rusted that almost all of them broke off, I welded new bolts to it.
Now for my problem, both indicator lights work amazingly, all of the bulbs work fine, and i connected everything like you did.
The first picture you have here shows the ground to frame right, but what is that copper strap? I did it exactly the same, cleaned the area really well and still no brake lights.
I don't know how to test if the power flows to it, I do have one of those electric test thingys but don't know which mode to put it on.
I bought my harness from Zip Corvette, the brand is Lectric Limited.
thanks in advance.
Old Jun 8, 2023 | 07:26 PM
loup68's Avatar
loup68
Army
The copper ground strap is for the antennae ground plane metal plate only. It has nothing to do with your brake lights.
Lectric Limited makes the best wiring harnesses. Do you have some place that you could take it to check out the no brake light problem? Lou.
Old Jun 8, 2023 | 07:41 PM
loup68's Avatar
loup68
Army
It could be the turn signal switch inside of the steering column. I hope that you have someone to help you with this in Norway. Lou.
To 68 rear light wiring harness
