Matching numbers
Old May 30, 2016 | 05:21 PM
Jerrysbb's Avatar
Jerrysbb
Default Matching numbers
It s my understanding that the actual vin number is stamped on the rear of the block( the last 6 digits of say a 68 or a 69 serial number) I see all the time people selling matching number vehicles which are not matching. I understand its a 50 year old vehicle so many parts will not be original. Am I right about the vin??
Thanks in advance Jerry
Old May 30, 2016 | 05:40 PM
Alan 71's Avatar
Alan 71
Hi Jerry,
The VIN derivative was stamped on the engine at St.Louis.
It was typically stamped on a pad on the block's surface located just forward of the front of the right-side head.
The pad also contains a stamp done at the engine plant, (Flint (sb), or Tonawanda (bb) ), that indicates when the engine was assembled and in what h.p. configuration.
The upper rear flange of the block contains a casting number and casting date for the block.
There are many, many cars that still have the engine they left St.Louis with. There are many cars that are described as having the engine they left St.Louis with, but in fact may not.
There's much to learn about "matching numbers".
Regards,
Alan
Note position of the 2 stamps are reversed on the bb and sb pads.
A bb stamp pad. (Head is removed.)
A sb stamp pad. (Head in place.)
Old May 30, 2016 | 06:02 PM
vettebuyer6369's Avatar
vettebuyer6369
In case you arent clear, this photo shows where the engine pad is that Alan posted, only a little farther back so you know where it is. It is in front of the passenger side valve cover. This picture has been posted around the forum a few times.
On a small block, the VIN derivative is on the the left side and the assembly code is on the right. Its the opposite on a big block.
The VIN derivative is also found on the transmission case on a 68/69 if thats what you are researching. Other part numbers may be "correct" or "appropriate" or date correct, but the numbers wont really "match" as there are no VIN derivatives. Paint and trim codes on the trim tag can match, but theres no VIN involved.
Old May 30, 2016 | 07:41 PM
LS4 PILOT's Avatar
LS4 PILOT
Block casting date and part number are on the back of the block in RAISED digits ....these were cast into the metal from the foundry .
The ViIN vehicle number was STAMPED into the FRONT of the block by the corvette factory at time the car was built......on the small pad below the passenger cylinder head . This is a partial VIN on the block , not the whole VIN on the windshield pillar or your Registation .
I usually check the raised block casting number first to be sure the block was cast in the approximate date for the car . The raised letters are hard to,fake . The stamped block pad is sometimes lost to machining work and restamped.
Old May 31, 2016 | 10:49 PM
Jerrysbb's Avatar
Jerrysbb
Originally Posted by Alan 71
Hi Jerry,
Regards,
Alan
Thanks Alan you are always very nice and informative. I am going to try to find my engine this is why I ask. I haven't pulled my tank to find out if theres a sticker yet but I may soon.
On another post you told me the tach for a SB was 6000 red line I thought 6000 red line( not orange line) was for a BB, Thanks again Jerry
Old Jun 1, 2016 | 07:50 AM
Alan 71's Avatar
Alan 71
Hi Jerry,
I believe these are the hp/redlines for 70-71-72 cars:
300/270(sb)/200…..5300
390/365/270(bb)….5600
350……6000
370/330/255…..6500
Regards,
Alan
Old Jun 1, 2016 | 08:27 AM
tokim's Avatar
tokim
A lot of emphasis on "numbers matching", as far as value, collectability, rarity, etc., yet it has been established that less than honest people have been re-stamping blocks to achieve those benefits.
Like LS4 PILOT stated, always a good idea to check the raised block casting numbers also (to at least determine, if it is even possible to be the "factory correct, original" engine).
The re-stamping of numbers, along with the ever increasing popularity of modifying these cars, will put less importance on the whole numbers matching issue (as with anything, there will always be exceptions).
Old Jun 1, 2016 | 08:46 AM
rmgny44's Avatar
rmgny44
Hi Guys,
Can someone clarify exactly where to find the "raised" casting number and date?
Old Jun 1, 2016 | 09:00 AM
Alan 71's Avatar
Alan 71
Hi R,
The block's casting number and casting date are on the rear upper surface of the block.
It's to the rear of the distributor and forward of the bell housing.
Look a little to the left and right of center.
Regards,
Alan
Small block casting date: L310….. December 31, 1970. Engine went in a car built mid-January 1971
Casting Clock: tells what shift and what hour of the shift the block was cast. (T indicates 'twilight', second shift.)
To Matching numbers
