coil springs
Old Jun 8, 2016 | 04:49 PM
nspctr1's Avatar
nspctr1
Default coil springs
I'm reassembling the front end after installing new control arm bushings and ball joints. The motor is out of the car. I can't get the spring to compress enough to set the nuts on the ball joints. I am using a compressor to assist. Any ideas on getting this back together?
Old Jun 8, 2016 | 05:25 PM
bj1k's Avatar
bj1k
Do you have the spring compressor spiraled up on the spring far enough ? Try taking the tension off of it and get more of a bite on the coils. I have never seen a situation where the compressor would not draw down enough if it is installed correct.
Old Jun 8, 2016 | 06:43 PM
DUB's Avatar
DUB
You need to either post a photo of the spring compressor you are using or attach a link to it so we can see it.
This is the one I use.
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/T4MAAOSwzrxUzM6j/$_3.JPG
Another view of it. I DO NOT use the fork attachment at all.
http://i.ebayimg.com/00/s/MTI1OFg5MDA=/z/Xw8AAOSwezVWu2CT/$_1.JPG
The engine DOES NOT need to be in the car to do this.
DUB
Old Jun 8, 2016 | 08:04 PM
nspctr1's Avatar
nspctr1
Dub, thats the one I'm using. It collapses one side of the spring only for some reason. I've adjusted the foot and everything but can't get it to compress evenly. The coils are about half an inch from touching each other and the ball joint is about 3" away still.
Old Jun 8, 2016 | 08:05 PM
nspctr1's Avatar
nspctr1
do you use an impact on the compressor? I've not yet but thinking about it.
Old Jun 9, 2016 | 07:28 PM
DUB's Avatar
DUB
YES...it WILL do that. It WILL NOT pull it up even. The trick is to make sure that you install the coil spring compressor to LESSEN the ANGLE.
When you have the tool hooked on the spring....you want the hooks to go SIDE TO SIDE and NOT front to back. And I can not remember if the longer hook is closer to you or not.
QUESTION 1: Are you putting in factory correct springs or the Vette Brakes and Products 400+# coils springs????
QUESTION 2: When you write. the ball joint is about 3" away still. Which ball joint are you referring to...upper or lower?????
QUESTION 3: When you have the spring compressed.... as you stated.... where the coils are about 1/2" form touching each other....IS the spring in the lower control arm in the pocket as it needs to be?????
YES...I use my air impact on this when compressing the spring.
AND...even though I know some guys who do it....they only use ONE hook and hook it to the inside of the spring area opposite of you being right there in front of it... so it pulls the spring back towards the other side of the car. I ...personally do not like that due to the stored energy that this spring will have and I have been at a shop a LONG time ago when the guy was installing a spring and it let loose...and not needing to get into specifics....lets say...it WAS NOT GOOD.
DUB
Old Jun 10, 2016 | 09:28 PM
nspctr1's Avatar
nspctr1
OK, The springs were the stock ones that were/are on the car. don't see need to replace them. anyway, I did away with the compressor and did a trick my buddy told me about. Take a strap and wrap it under the jack, upper and lower control arms and frame, tighten strap an jack up lower control arm with spindle attached to lower ball joint. The strap will keep the car from rising and actually bring down the upper control arm a bit. It worked like a champ. Thanks for the help. Still gotta do the PS but gotta work this wknd.
Old Jun 10, 2016 | 09:30 PM
nspctr1's Avatar
nspctr1
HOWEVER, the upper ball joint is not cinching down all the way. There is a small gap between the 2 mating surfaces, the spindle and ball joint. I have tightened the castle nut as far as I can by hand and have probably 2 threads max before the cotter pin is rendered useless.
Ideas?
Old Jun 10, 2016 | 10:14 PM
530planeman's Avatar
530planeman
I posted a reply with pictures while back .I use a piece 5/8 fine thread all thread sod I get from fastnail with two nuts and washers on eack works very easy PM me an text or email I will send a picture
Wes
Old Jun 11, 2016 | 01:50 PM
ronarndt's Avatar
ronarndt
DUB
" I ...personally do not like that due to the stored energy that this spring will have and I have been at a shop a LONG time ago when the guy was installing a spring and it let loose...and not needing to get into specifics....lets say...it WAS NOT GOOD"
I saw one let loose from an improperly fastened coil spring compressor and fly thirty feet across the garage and break the passenger window of another car. Some people put a safety chain around the spring as a fail safe measure.
Old Jun 11, 2016 | 03:13 PM
jr73's Avatar
jr73
absolutely
To coil springs
