My windshield in my 77 has been cracked since I bought it, over a year ago, and I finally was going to get it replaced today, but when they pulled the windshield it revealed the bird cage under the lower driver side corner of the windshield was rusted. I haven't had a chance to see exactly how bad it is as it started dumping and I don't have a garage, but it definitely has at least one or two small holes. I don't have the time or money to fix it properly right now. Does anyone have any ideas for a temporary fix that would allow me to get a windshield in it and hopefully prevent it from getting worse?
Depends upon how bad it is, If the metal is thick enough at the holes you can weld it or weld plugs in to close the hole. Chances are the metal is very thin.
Wire brush what you can, bondo the holes, paint with Rust Bullet or the like.
Use Urethane to seal the thing up. Run a bead along the top and sides of the rear fender mount (its rusted under there)
Never use silicone on a car... always urethane. If you ever have silicone in any spot you will never get back good adhesion of paint in that area. Urethane is the proper material to glue body parts (no matter if it is fiber glass or sheet metal).
I am no expert on rust, But I will say the forum members have provided you a wealth of information. C3's are true affordable dream cars but they are vintage cars and require attention.
I have used a product called RUST MORT that I got from a auto paint dealer ,paint it right on rusty area let dry then paint the brown rust oeloum primer and then use the strip pieces of windshield sealer
good luck Wes
If the hole is that large, by the time you grind it out it'll be three times larger. I'm not sure of your skills, but conversion primers and bondo won't solve the problem it'll just delay the repair.
If this was in my shop I'd cut out the bad area and weld in a repair.. I'd also pull the driver side dash pad and check the integrity of the lower reinforcement. See how much damage has been done to it from the water leaking inside the car and lastly I'd remove the kick panel and check the condition of the lower A pillar. (where the water ends up).
If you go to our Facebook page you'll see where we just finished repairing a 1969 with probably the worst damage to a lower A pillar I've ever repaired.
1. Do the repair properly as Willcox described and never hear from that problem again;
2. Use a Dremel or small hand tool to scrape/whittle loose, damaged material from the 'bad' areas, then fill with some J.B. Weld stick epoxy to seal up as best you can do by yourself (ie, 'Bubba patch'). Not the best way to go, but better than doing nothing.
3. Do nothing. Don't drive it when raining and don't put water in that area when washing the car.
P.S. If you are finding areas like that with just the windshield removed, there is MORE elsewhere in the birdcage. (kickpanel areas, etc.)
What does it look like across the top? That's where mine had it bad. Poor design with the seam in the trim across the top. Perfect place for water to get in. Keep it well sealed.
I would love to fix it right but I don't have the money or desire to pay a shop to do it and I leave to start at USMA in two weeks so I don't have the time to do it myself right now. The car will be sitting in a garage driven less than one month out of the year, if at all, for the next 4 years, until I graduate and have time to work on it. I just want to prevent it from worsening as much as I can and make it so it can drive if it has to. The upper part of the windshield frame also has a little rust, but it isn't bad. There are no holes and it's not soft it just needs to get stripped and painted. The bottom of my birdcage, behind the kick panels is super solid, there is hardly even any surface rust down there.
Originally Posted by 7T1vette
You have at least 3 choices:
I was thinking along the same lines as your 2 and that is likely what I will do.
Thank you all for the input. It is much appreciated.
When the body shop was reworking my 72 body they found the same issue. They cleaned the rust, treated and used fiberglass to patch the holes. So far, no issues.
