Put in 2 and a half cans of freon air still don't seem cold enough also air don't seem to blow very hard. Any thoughts on this?
YES..I have a lot of ideas of what can be wrong...BUT...take it to someone who knows A/C. Unless you do know about it.... and if you did...you would not be asking..... because you better BE CAREFUL in doing what you are doing because the high side can get WAY too high and you actually cause more of a problem than if you took it to a professional. Not knowing if it is R-12 or 134A...and if it in a Corvette that WAS R-12 but converted to 134A...where you DO NOT put the same amount of freon in it.
DUB
It has been changed over to 134 A. I think the main problem is it just dont seem to blow very hard. The guage shows it has the correct amount of freon in it. Any thoughts why it dont blow very hard. Other people I talk to say theirs has the same blowing problem.
For what this is worth to you.
IF the air was not blowing hard...adding more freon will not change that.
Adding more 134a freon into a system can be dangerous due to IF the system called for 3.25 lbs of R12....you DO NOT put 3.25 lbs of 134a into it.
AS for the air not blowing hard....it can easily be. The foam seals that seal off the junctions in your ducting system are worn out and air is escaping at these junctions.
Also...there can be a lot of leaves and debris BLOCKING the front of your evaporator core...thus...reducing the air being able to flow through it. I just replaced an evaporator core in a 1972..and the amount of leaves in front of it was a JOKE.
I have an air flow meter where I can record what the air speed coming out of the center duct is before I start and what it is when I am done. And it also lets me know how hot/cold the air is coming out of the vent also.
[QUOTE=DUB;1592416227]For what this is worth to you.
how do i go about checking for leaves etc in front of theevaporator. do i have to take something apart to get to it.
With the A/C blowing on high, open the hood and feel around the air box under the hood. It'll be the box in the passenger side that the A/C hoses go into. This houses the fan unit.
Often times, this box gets gaps / cracks opened up and all the air blows out into the hood compartment. I have used varies things to deal it up; duct tape, caulk, body seam putty, etc.
See if you have air blowing out through the gaps. That may be your problem.
The 'easiest' way I know to get to the front face of the evaporator core is to remove the blower motor....then...going through the cowl ....down through where the blower motor was and towards the evaporator core. Using a vacuum cleaner with a protective tip and see if you get anything out....OR ...like I do...I use my borescope and actually look.
I'd also consider putting a 1984 or newer blower motor and fan on there. Real easy, lots of guys do it, all you need is a jigsaw and a piece of plywood to make a spacer. Plenty info on the forum describing it. Also, make sure the little hose that cools the blower motor is in place. I was repeatedly burning up blower motors before I knew of this.
I have done this and I am not convinced that it does any better than the original fan. The reason is the 1 inch spacer is basically shimming out the motor and fan..and this spacer is blocking that added 1 inch of fan that is theoretically improving the air flow.
I have yet to have another car where I replace the evaporator core so I know it is perfect..and try the original fan and then the later design one where I can actually read the air flow with my air flow meter. Once I do that...then I will be able to 'speak' with facts.
. Yes I do feel cold air at the seems of the blower box. Is that where it comes out or is there other areas on the box to check
That is a key area where you lose your cold air and power from the blower. If you tape up / seal up those cracks, the A/C will blow much harder and feel colder. Trust me!!
