Starter
Old Jul 1, 2016 | 12:12 PM
croaker's Avatar
croaker
Default Starter
How many of you guys are getting by with a stock starter with headers? Ceramic coated
Old Jul 1, 2016 | 03:14 PM
fishslayer143's Avatar
fishslayer143
My headers are not coated.. I tried 2 Mini Hi-Torque starters , both failed in 6 months.. went back to my OEM starter,...its been years without any issues
Old Jul 1, 2016 | 04:35 PM
billcarson's Avatar
billcarson
doing well with a stock style ac delco replacement starter and home made heat shield.no issues at all.
Old Jul 1, 2016 | 05:02 PM
76C3forme's Avatar
76C3forme
Very nice work there. I've fabricated more custom starter heat shields than i can remember on various cars. They make a world of difference, that's for sure.
Old Jul 1, 2016 | 05:27 PM
billcarson's Avatar
billcarson
thanks.it is made from a pipe insulation support hanger and ss nuts and bolts.
Old Jul 1, 2016 | 06:45 PM
croaker's Avatar
croaker
Wow that's nice!
Old Jul 1, 2016 | 06:46 PM
croaker's Avatar
croaker
Is it lined with anything?
Old Jul 1, 2016 | 09:00 PM
76C3forme's Avatar
76C3forme
It turned out great. I used to used Stainless steel sheet and bolts/nuts as well. Simple, clean looking and effective (and not that expensive ! )
Old Jul 2, 2016 | 06:28 AM
billcarson's Avatar
billcarson
no not lined with any insulation.seems to help though as air is a great insulator and it does not touch the starter at any point.
Old Jul 2, 2016 | 12:52 PM
fishslayer143
The solenoid is what needs shielding from excessive heat
carriljc's Avatar
carriljc
Default I have stock starter with ceramic coated headers
Have had for years. I had ordered a generic chevy starter shield ages ago and put off installing it for years. Still no problems, but one day I was under there so I installed it. I had to tweak it to fit, so you're probably better off fabricating as shown in post above to begin with.
Anyway, no problems for years.
Old Jul 2, 2016 | 04:03 PM
billcarson's Avatar
billcarson
you would have to think that most of the damaging heat comes it idle while stopped.i never ir gunned it but believe that the shield deflects enough of the heat to help the starter and the solenoid.good point though about the solenoid needing protection as well.
To Starter
