What's it worth?
Old Jul 1, 2016 | 03:21 PM
Akadeutsch's Avatar
Akadeutsch
Cruising
Default What's it worth?
New here. First post. So, I kind of fell into a 1980 L82 T-top. Its Rough looking but with good bones. With new gas the engine fired right up after around 4 years in storage. It has been running strong for a couple of days now and starts very easily, even in the morning. It will need a little bit of body work and paint, new seals, things like that. But its generally a solid car i think. All original, number match. What should i offer for the title?
Old Jul 1, 2016 | 03:24 PM
71 Green 454's Avatar
71 Green 454
Posting some pictures would really help.
Old Jul 1, 2016 | 07:01 PM
Akadeutsch's Avatar
Akadeutsch
Cruising
Did this work? I hope it helps.
Old Jul 1, 2016 | 08:40 PM
TMU's Avatar
TMU
St. Jude Donor '09-'10, '15, '17
Thinking $3k-$4k. If concerned with originality I'd verify the engine numbers, looks like crate motor valve covers.
If you are not familiar with areas prone to rust read this
https://www.corvetteforum.com/forums...-corvette.html
Old Jul 2, 2016 | 08:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...All original, number match. What should i offer for the title?...
The Goodwrench valve covers are not stock and suggest an engine replacement to me. Have you checked? L-82s had the finned aluminum valve covers. Otherwise, not a bad car. Glass tops? What is the seller asking?
Old Jul 2, 2016 | 08:57 AM
Eljay's Avatar
Eljay
No rust up to $5K
Old Jul 2, 2016 | 09:30 AM
Viss1's Avatar
Viss1
Assuming it's a NOM and solid frame, if it were mine I'd ask around $5000 and be OK with anything in the low $4's or higher.
Old Jul 3, 2016 | 08:29 AM
Akadeutsch's Avatar
Akadeutsch
Cruising
Thanks guys. I offered a grand. Well see what they say.
Old Jul 3, 2016 | 09:22 AM
revneck's Avatar
revneck
A grand? Why just offer nothing?
Old Jul 3, 2016 | 10:35 AM
CrossWired's Avatar
CrossWired
Car is a none matching number (NOM) but 82 is the last year of the C3's. The car to some is a collectable as a result. Offering a grand even with a crate\donor motor you should give it away to a charity that buys cars for those in need.
Old Jul 3, 2016 | 11:24 AM
Akadeutsch's Avatar
Akadeutsch
Cruising
I offered them a thousand dollars because that's what i have. And because that's what i think it'll take. The car will not go to some charity. I'll be building it my self.
Old Jul 4, 2016 | 09:49 AM
terry82's Avatar
terry82
The car is worth up to $3000 maybe.it needs a lot .not the best color {imo}it will need paint any way.Your offer is a good starting point .go up If you really want the car .There is a lot of work ahead of you.
Old Jul 4, 2016 | 09:57 AM
terry82's Avatar
terry82
http://www.vettefacts.com/C3/1980.aspx
To What's it worth?
