Post Restoration Observations / Questions
- With all new brake lines and hoses, and new master cylinder, I did NOT bench bleed the master cylinder, and used MityVac plus gravity bleeding, and while the pedal is NOT solid like my 2015 F150, I believe it is as solid as it should be, and braking action is great. Myth busted!
- I am getting an annoying grinding / pulsing noise coming from behind me when driving, mostly noticeable as I slow down, and goes away with brakes....although, it would given the car is no longer moving. I don't know what it is, but the rear hubs are brand new / rebuilt, all new Spicer solid U-joints and overhauled differential....don't know what it is. I have adjusted the parking brake, and cannot isolate where the noise is coming from. I have jacked it and spun rear tires by hand, and cannot hear a thing.
- As previously posted, my engine is awesome, especially when you get on it.
- I just installed a new temp gage to replace original that had pegged to the right, put a new printed circuit board in, and my clock came to life on its own! Bonus.
- I have a Dewitts aluminum radiator, and the temp gage doesn't exceed 160 degrees...so I need to use a laser temp sensor and see what it is really doing??
- My fuel gage was bouncing around, so I put a new one in, and now it doesn't.
- Despite a newly rebuilt steering box by a vendor, a new NOS rag joint, and a completely rebuilt steering column, I still feel the steering has play and will be sending to Gary Ramadie this winter....but maybe I just expect too much out of the system....its not rack and pinion. I just wish it was tighter. Newly rebuilt power steering valve, but am I expecting too much to expect that a small movement of the steering wheel results in movement of the car?? IN other words, is there a certain amount of freeplay that is just how it is in these cars?
- The 4 speed manual T-10 is crude and sloppy, and with 3:55 rear end, the RPMS run higher than by DD, but I wouldn't change it. I love the character of it.
- I will be happy to post some good pictures once I take the time to take them.....I put lots of hard hours and dollars, and rebuilt or replaced every piece of this car....mostly myself, and have to say I am proud of it, and it feels good. For me, it was all worth it. Now, I will drive it.....alot.
Good luck, keep us updated
No idea if this has anything to do with what you`re getting, and if it is, it may not be there when the car is jacked up?
Not saying this is your problem, but you never know......
Good luck....and only noticed with weight on the suspension.
