79 vette. Trying to decode this number but not making sense.
T4FY22651. I'm sure this is not original but I can't figure what this motor is out of.
Does any vette guru know what this might have come out of and what it may be??
A pic of the number and it's location would be helpful. A casting number would be of some help too. You should be able to find the partial vin and engine ID number on a pad located in front of the passenger side head.
Take another look at the number. If it is supposed to be an engine ID stamp, the format is incomplete as posted and appears to contain a consecutive unit number. It is also not a VIN derivative. A pic would help.
I will look again to see if that could be an F instead of a 4. This is the engine stamped number on the front passenger side.
Should some of this number be in the VIN #.
There should be two stampings on the pad. The first is the engine ID stamp. The second should be a VIN derivative of the car the engine was originally installed in. The two should not overlap each other, but stranger things have happened.
TFY could be part of the engine ID stamp, but you are missing other characters. 422651 could be a consecutive unit number from a VIN derivative, but, again, you're missing characters.
Hi M,
The surface of the pad (the circular groves) are an indication that the block has been 'decked' since it was originally built at an engine plant.
This has apparently/likely removed the original stamp that was put on the pad when the engine was assembled.
The information on the pad now MAY be something stamped by the 'rebuilder'.
Does any of the sequence correspond to part of your car's VIN? Evebn a couple of digits?
Regards,
Alan
Added: Hi s, you posted while I was rounding up the picture!
Here's a more typical sb pad with the Engine Plant stamp identifying the engine, (black), and the St.Louis Plant stamp identifying what car it went into (white)..
Hi M,
Regards,
Alan
No numbers match anything in the VIN. Looks like the casting number is 3970010. Looks like dial on date stamp points to 9 oclock???
casting number shows 69 to 79 350 so I guess it is at least period correct. Guess it's been decked. Just wish I knew the horsepower but I'm guessing probably around the 195. Not that mean at all. Just good cruiser. Was just wanting more power (maybe crate engine) but didn't want to do that if this was original but I guess we can see it is not. If original was thinking of a rebuild.
Hi m,
The 'Casting Clock' on the rear flange of the block has 2 pieces of info.
First to the right is the 'Shift' indicator… D, T, N. I believe T represents the twi-light shift.
To the left is a 'clock' that indicates what hour of the indicated shift the block was cast, not what time of the day it was.
Regards,
Alan
This info isn't really of much use today.
This block happens to have been cast late on the second, (twilight), shift of December 31 (L31). So the foundry was working, and the block was cast on New Year's Eve 1970.
Lets make the assumption it has been decked then, okay, some work has been done on the engine. If now you might want to lift the valve covers and see what heads are on it, then remove the intake and see if it has been bored. Like I said, you are now entering the element of research and discovery. Once you have it apart you can make your decisions about rebuilding it or replacing it with a crate engine. With a nice cam; some aluminum heads, an aluminum intake, you can start to pick up some nice HP on the engine that you have. Great winter project for sure. My mild mannered Sparty 1971 picked up some new heads, a new mild loping cam, new intake and new carb (all originals are here, just not on the engine) and now it is far more spirited than its original 270 HP. You can easily get 300 HP out of that engine you have, why not have some fun with it?
Best regards,
David Howard
AllC34Me
Thanks for all of yalls help. Might be a fall or winter project.
