Vacuum lines?
Old Aug 13, 2016 | 10:00 PM
Skip Burney's Avatar
Skip Burney
Default Vacuum lines?
Guys I am trying to find a better way of running the vacuum lines on the back of the engine on my 73. I have to run lines for the brake booster, PCV and headlight accumulator. I have a port on the carb and one on the intake. I am always looking for a better way to do things does anyone have any pics of how they did theirs? Thanks
Old Aug 13, 2016 | 10:28 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I used 3/8" steel fuel line and replaced the rubber hoses at the back of the engine to clean it up. The steel lines I ran tie into the booster/canister rubber hoses just off engine. I'm running a Billet Industries hidden pvc at he back of my alum valve cover and tied the steel line into it there. It really cleaned up the back of the engine. If you are handy with a tube bender, it's easy.
Old Aug 13, 2016 | 10:35 PM
Skip Burney
I think I see what you mean if you have a pic I would love to see it. Tubing bending is no problem at all.
Old Aug 15, 2016 | 07:08 PM
DUB's Avatar
DUB
I use all so the sizes of stainless steel brake line...depending on the system requirements.... and I can put that bubble at the end of the line so the hose has something to seal against....instead of a line that is just cut-off.
I also fabricate billet aluminum custom line holders to secure these lines when ever necessary.
I cannot post any photos of work installed because people pay me to do work for them and it has been understood in most cases that it is NOT to be out on the web. It is up to them to do that. And you finding a routing path and figuring out how YOU want it is all that matters.
DUB
Old Aug 15, 2016 | 07:33 PM
kanvasman's Avatar
kanvasman
As Dub said, put the bubble at the end of the cut lines using a double flare tool . That is a cheapo tool that has a lot of uses, starting with messed up brake lines.
Old Aug 15, 2016 | 10:30 PM
Skip Burney
I have a full set of internal beaders that I use on aluminum fuel lines on antique aircraft, yep some of them actually use rubber hose and clamps. But what I did was take a 3/8 inch stainless line and turned out a 1/4 stainless hose barb on the lathe and drilled into the side of the 3/8 tube and silver soldered the hose barb into it to make T fitting 3/8 on the run of the T and a 1/4 barb on the bull of the T. I cut it into the brake booster line behind the left cylinder head and no one can even see it. Those el cheapo beaders are nothing but trouble. I have a set of Roper Whitney beaders that are over 40 years old and still work like new. You just don`t try to get the full bead in one roll. I was just wondering how some of the other guys ran their lines.
To Vacuum lines?
